Thanks for your concern. It's sold.
Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
- Thread starter xLoud
Silent Xaxal
- May 16, 2014
Croptop
- Dec 20, 2014
may have found another issue with new firmware. awhile back fiio fixed the issue with the X5III and the DK1 docking station. before it was fixed the volume of the line out would be cut in half after being paused, and required it to be unmounted then replaced in the dock station for volume to return.
This was fixed. now when docked i get half volume again and undocking and redocking does not bring volume back. this was working and now does not. I run the docking station to a Asguard 2 schiit amp, and this is working with a fiio XI and X3 II
I use my X5III in a K5 dock all day at work and I haven't noticed the return of the "half-volume after pausing" bug. That bug was driving me nuts in the past so I would certainly notice if it had returned. I'm not sure what, if any, difference in protocols when interfacing with the DK1 vs the K5 but -- thankfully -- things are still working for me. I just have headphones plugged into the K5's headphone port.
SoundSquare
what for ? the X5 III can only output 2 channels, so you'd miss some parts of the music, unless it would downmix to 2 channels, but then it would be awfully mixed.
No need to bother Fiio with such a feature that woiuld please less than 5 users, instead they must focus on bug fixing (and advertised functiuns that still don't work such as usb audio)
spanner43
Yes i as wondering how similar the issue with k5 and dk1 might be. with this update my issue is a little different. its not that it goes to half volume when paused. it is now always at half or muted volume. I am now able to crank my asgaurd 2 up to full volume to a sound that is more like 1/4 volume used to be. again the dk1 still works fine with my X3II and X1 players.I use my X5III in a K5 dock all day at work and I haven't noticed the return of the "half-volume after pausing" bug. That bug was driving me nuts in the past so I would certainly notice if it had returned. I'm not sure what, if any, difference in protocols when interfacing with the DK1 vs the K5 but -- thankfully -- things are still working for me. I just have headphones plugged into the K5's headphone port.
thank you for your response
everytime I switch my X5III on since the last update it want to scan tracks from 0
Jjc27
- Sep 17, 2014
Just recently got my hands on this beauty of a dap. Just made a search through the forums but I find no mention on the kernel source. Has fiio not made the source available yet?
Kundi
Has anything been said about updates to widgets? Either existing ones or ones that are coming? (Pocket Casts please!)
spanner43
Okay, looks like its back working with current firmware, I did a factory data reset and volume is as it should be with DK1. now to set everything back upmay have found another issue with new firmware. awhile back fiio fixed the issue with the X5III and the DK1 docking station. before it was fixed the volume of the line out would be cut in half after being paused, and required it to be unmounted then replaced in the dock station for volume to return.
Will go back to last firmware until this can be looked at.
My x5iii has just decided to do that too.everytime I switch my X5III on since the last update it want to scan tracks from 0
Edit:
Edit: With the SD cards in Local Music, I have discovered that the Fiio X5iii is not listing tracks in the correct order on some albums. This is particularly noticeable with classical music. Maybe I need to tag these albums differently? It is such a pity as it is a lovely sounding DAP.
superuser1
Furthermore, have now discovered that the X5iii isn't playing nicely with the 256GB cards. In Local Music, not only are both SD Card 1&2 libraries showing duplicate tracks on many albums but also listing the tracks in random order. Quite frankly, it has made a bog of organising the libraries. I tried deleting one or two duplicate files only to find the original files wouldn't play! It is such a pity as it is a lovely sounding DAP.
When ever i press skip the song playing is just restarted. I dont know what to do except factory reset it. In other news the Black Label is in the house!
Signal2Noise
Is the X5iii still a good buy now that the X7ii is inches away from release?
I've read/heard the X5iii is arguably a better buy than the original X7. The reason I ask is I am interested in the X7ii but I just bought the DX200 which I'm totally enamored with. However, I don't dare take the iBasso out of the house for fear of theft or damage as it''s the priciest DAP I currently own. The Pioneer I use at work, mostly Podcasts, zero MQA files I have some gift cards to burn and X5 price has dropped a little bit. Not to mention that Red version looks mighty sweet. I've never had a FiiO so figured the X5iii might be a good one to get for travel, something different, and utilize another set of idle IEMs I have in my collection.
Thoughts?
Thoughts?
imo, do you plan to use X5III with a line out amp.Is the X5iii still a good buy now that the X7ii is inches away from release?
Thoughts?
If you just use SE out. I highly recommend waiting for x7ii. You get twice ram, and other hardware improvements on x5iii. You plan to use any apps? definitely wait for x7ii
Changeable amp modules? yep!
Also maybe you might end up liking x7ii more than dx200. things happen lol
Signal2Noise
I could. Maybe my Mojo would see more action.
I use balanced & SE. Preference of course is balanced but when traveling I'll use SE for battery longevity.
I do have app preferences. However I did read that the default player/Viper is pretty good on the X5. Won'tknow until I've heard and used it myself.
Yup. Thus is the nature of this never ending hobby/way of life. X7ii is definitely on my radar but I'll hold out awhile at that price point as well as maybe other color/finish options that may appear.
Thanks for taking the time to comment.
@Signal2Noise
but tbh, you can't go wrong with x5iii if you are looking for a non-pricey all in one dap.
if you do get it, enjoy!
