I already decided on the Agni, but yes I was at MYIEM. I'll try it out next time I visit, though I am very unfamiliar with Brise.
I think I learned a lot today, there was a customer there who builds his own cables and I learned a little bit about different cable materials, builds, and solders. He recommended the OC AuX on grounds that it is made with better materials than the HS Agni and that changing the solder should brighten up the sound. Though I was intrigued, in the end, I decided the Agni was more in line with what I need at the moment, which is more detail and better spacial performance. I'll eventually buy the AuX too, but probably not for the A12t.
Speaking of other iems, I also learned that gold will slow transients compared to silver, resulting in the AuX's huge subbass. In my really dumb plans to have piotrus internally rewire a future F7 that I really hope to get the funds for, I'll probably end up buying some gold plated wire for the "bass" drivers and silver wire for the "tweeters". Not too sure about "mid" drivers yet, probably going with silver.
Oh yes Crystal Cable's slider is just a piece of clear plastic and is pretty hard to move around. Crystal Cable's splitter is pretty much a small plastic luggage tag, that's my main gripe with it, mine hasn't broke or anything.
My favorite splitter/slider combo is probably PlusSound's.
Notwithstanding SQ, Superbax and 1960 2w are what i would consider ergonomically ideal cables. the slider on the superbax is a joy to use, and i am a fan of discrete cabling.
