HiFiRobot
- Apr 1, 2013
Bought the Focal Clears apx 1 year ago. I had heard them a few times at stores and hi-fi shows. I really enjoyed the clarity and separation and thought to myself: I wonder if these would pair really well with the right tube amp?
So I am currently 1 year into testing them out with my everchanging collection of DACs & amps. And I might as well post it here as well, as it might be of interest to someone else.
Source is desktop PC running Spotify and Tidal Masters, Raspberry Pi Volumio, Bluesound node 2i or iFi Zen Stream. Tidal should be on a bitperfect chain when on PC at least, dont know about the streamers. I dont EQ. Interconnects varies but USB is usually Supra or Wireworld Ultraviolet. Power when not on battery is using Supra Lorad, Isotek or Pangea cables connected to Supra LoRad MD06-EU MKII mains block.
I use the Focal Clears for music and casual gaming. Music ranges from proper hifi stuff like Agnes Obel, Leonard Cohen and tracks i Shazam at hi-fi shows to lots of electronic music, folk-pop, acoustic, hip-hop, some rock and then many other genres which I don’t even know the name of. I’m pretty open to any tune as long as it sounds good. But not much Classical or Jazz.
All impressions are my own. And I might even change my view when I revisit a combination later after more listening
. Likely many will be of different opinions on which pairing they prefer.
Anyway here goes:
Focal Clear pairings pt1:
Geek Pulse Xfi (2x ES9018K2M, 2x Femto clocks) + SBooster 12V doing quite well. Perhaps bit more weight to the sound is needed. Amp part of the Geek Pulse Xfi is kinda light weight.
Focal Clear pairings pt2:
The search for magic synergy continues. Added JDS Labs Atom to the mix. A great entry-level amp. DAC is still Lh Labs Geek Pulse XFi + SBooster 12V PSU. This combo sounds good. But (to my ears) something is still missing, need to try out the Focal Clears with more gear.
Focal Clear pairings pt3: LH Labs Geek Out 450.
This is now a 7 year old DAC & AMP, but still extremely good sounding to my ears. It uses a very well implemented ESS9018K2M DAC chip. I think a lot of stuff released after and to higher pricepoint than the original $149-199 RRP simply does not compete. The GO450 drives the Focals with really good authority, clarity and a nice tonal balance. Some slight tizziness on hi-hats and such on poorly recorded stuff, probably due to the clarity from both headphones and DAC/AMP. Soundstage could be bigger not getting the holographic feeling I am looking for. But considering these can be found used for 60-120€ it’s a solid budget/starter option for the Focals. And actually for almost any headphone, as my GO450 and GO1000 play well with everything I have tried them on Denon, Fostex, Audeze, Hifiman, HD6xx etc. For Focals I’d stay away from the Geek Out 1000 (usually red coloured) model as its get loud too quick. It’s really sad the Geek Out is not produced any more, maybe a steady revenue stream would have saved the company?
Anyway here goes:
