dpump
- Jun 23, 2001
13 ft is just about right for me.Its about time headphone manufacturers started giving us decent lengths of cable,anywhere from 10 ft.
Assuming the Elear cable is good enough, I will eventually cut mine in half and reterminate so I have a balanced and an unbalanced cable. The cable with the stock 3.5mm connectors will have a 4-pin balanced connector on the amp end and the cable with the 1/4" connector will have 3.5mm connectors on the headphone end.
However, I'm always wary of stock cables. Just because the cable has a thick housing doesn't mean the actual wires inside are very thick. I've cut some stock cables that were impressive on the outside but had very thin wire inside, so you see a wire that looks like the typical wire on a lot of mid price headphones. The stock cable often has some 'filler' inside to make it thicker and to give the impression that it is a high end cable. Unless you can find a picture of a cable someone has cut you won't be sure what size wire is actually being used. I'm not sure why so many manufacturers shortchange their phones with what I consider to be a somewhat substandard wire. Of course that keeps the aftermarket cable guys in business but degrades the potential of the phone.
