leo5111
- Sep 5, 2005
to anyone interested the cable came today, seems to be high quality,sounds fine to me
Hopefully the community can be of some help here. Typically I am an open headphone guy but a while back I had some Denon D2000 and really loved then but like we so often foolishly do I sold/traded them and have regretted it since. I was at a meet and got some head time with Fostex TH900 and a Chord Hugo. For me that was bliss and endgame as far as I was concerned with closed headphones. Th-900 were out of my price range though but with the recent Massdrop Fostex Th-xoo line I thought that would be a good compromise and I was nearly set to pull a trigger on a pair when I got a lucky break and scored a pair of Fostex TH-600 at a price I couldn't pass up. I was going to purchase a pair of thx-00 maple cups form Mark Lawton but alas they were sold and the page hadn't been updated but no worries as we worked out a deal on a new type 1 wood cup that they used to test before they go into production he is having it glossed/finished and I should be getting it in a few weeks. I am going to change the stock pads as well so any recommendations between ZMF pads, Lawton pads ($109 seems a bit high just for pads) or anybody know if Mr. speakers alpha pads will fit a 600 or any other suggestions? Also I am not the greatest craftsman in the world and a bit inexperienced modding headphoones - is changing the cups that difficult or so technical I should find somebody I know local do it for me?
As always thanks in advance for any tips, help or recommendations.
After headphone is complete, next purchase will most likely be a chord mojo for portable use - Have a good solid state and tube amp as well as DAC already for home use.
What portable amp sounds better then Fiio E12 with these headphones? dont get me wrong my E12 sounds fine just curious if there was a portable amp that sounded even better with them
Tell me which one that suits TH600:
Order the ZMF Pilot Pad?:
Select Order the ZMF Pilot Pad? YESNO
Order ZMF Earpads?:
Select Order ZMF Earpads? NOYES
Earpad Shape:
Select Earpad Shape Pilot Pad OnlyOvalOmni
Have no idea with this.........
http://www.zmfheadphones.com/order-the-zmf/zmfpads
Depends what you want. What are you trying to do?
If you want more bass, get the cowhide.
The cowhide will act a lot like the bass boost, but I think mids and highs are still pretty good. That said, if you are happy with the bass boost and EQ, then there is not reason to change.
