So I went to EarFun's site to see if the discount code
@tma6 posted would work, Unfortunately it did not. I tried Welcome30 and it gave me 30% off. It took the price of the Earfun Air Pros to $56, it doesn't look like they are shipping to the U.S. what a bummer.
Depending on which TWS you already own and if the Earfun Air pro are anything like the Edifier TWSNB2 I just received, I wouldn't recommend them much.
- They do not stay put in the ear (yawning or laughing/smiling openly will always break the seal have have the bud start to dislodge and/or fall).
- The SQ is decent but not exceptional nor particularly engaging. If you have some good TWS, chances are this one will fall into a position where the SQ will not draw you toward them more than another you already like.
- The case feels cheap, is annoying and not convivial to open without looking at it to figure the right side to open it and even then, you need some nails to manage to have some grip on the microscopic edge the case has. Those biting their nails, beware.
- 1 week old and 2 hours on them, at about 90% charge before being put in a fully charged case, yet 1 bud was already dead by leaving them in the case sitting on the desk for 3 day. Managed to salvage the bud which wouldn't charge by plugging to small wire between the charging port of the bud to a small lipo battery, which gave it enough charge to be recognized by the case afterward.
- Call quality is really bad, at least if you only use 1 bud. Have not tested 2 as situation didn't arise yet, but my wife told me it was the worst she ever heard form me, often not being able to understand what I say. Pretty bad knowing I previously was using a cheap 18$ 1 ear call bud.
- Did I say the ergo are simply bad? I shared them with a friend while working to have his opinion and bending down, the bud fell down multiple time on him as well. I might have weird/small shaped ear, but he told me this was a first for him.
- Even thought it doesn't matter much, the box and included charging cable feels cheap/average. In fact, I have to jiggle the cable multiple time for it to charge my phone. It is an issue I have with cheap cable but that quality one do not have. I must confess it currently has no issue with the case but it does give the impression it will not last long.
It might seems pretty negative, but take it with a grain of salt. It simply means that to me, it has ok SQ but is pretty average for the rest. Someone who don't have any OK TWS and doesn't want to spend a lot should like it, but someone with others IEM available might find it underwhelming.
