dweaver
- Dec 23, 2008
Having both, I would say if you like a more visceral sound the MTW3 is the better choice. If you have a phone that supports the higher APTx codecs it becomes even more appropriate.Very good price....I think they are probably worth it at that price. I originally said 150 so we are getting close. The question would be these or the MTW3 at the same price.
If you prefer a wider sound stage with more spatial sound then the Elite 10 is better option. If your phone does not support higher APTx codecs it then is an easy recommendation as APTx and AAC are pretty similar.
Out of the 2 I personally find the Elite 10 more comfortable. But the MTW3 is comfy and has better wind reduction using ANC and more passive isolation.
I actually am glad I have both still. If my wife say one has to go, I will likely sell the MTW3 because I like the Elite 10 spatial qualities more than the MTW3 visceral qualities.
