So I have been shopping around...I'm to lazy to post the mid woofers and tweeters I'm thinking about getting now but will tomorrow. Where can I find some of those fiberglass panels for them to mount them?
You make them - that's why DIYMobileAudio was mentioned
Or you get a local shop to do it, like I did - maybe DIYAudio can direct you to a shop or DIY-er for hire near you. But basically here are the steps before you dive into either direction, but detailed instuctions and photos are on other threads, mainly on DIYMA:
1)
Test-run the mounting first, particularly the tweeters,
for staging and imaging. I used blutack for about a couple of weeks on the Vifas, several more on other tweeters, just trying out other configurations; the safest though was still the best. That is, mounting the tweeters a little higher than the instrument cluster hump, then both aimed at the rearview mirror mount or just a bit towards the back of the car from that.
2) Cut MDF rings to hold the tweeters (and the midbass if you're doing those too), plus some scrap MDF to serve as support posts that you can easily trim as you go.
3) Use a glue gun to mount the MDF rings and support posts at the desired angles - you can use strings or laser pointers to help with this - then remove the pillar (plus door panel if you're doing that too), making sure you don't knock off or otherwise move these mounts in the process.
4) Rub some gorilla blue on the mounts, then spread a large enough piece of cloth over it. When this dries, work on gluing it to the rest of the pillar, gluing in more areas as the desired shape requires (like around the MDF ring, the feet, etc. After this follow how fiberglass is built onto this fabric (especially saffety procedures), which in short will be laying down resin, kitty hair, drying, then repeating for several layers. Usually three would be strong enough if the supports you used are tough and the tweeter light enough.
5) Sand then spray paint to match the dash, interior or original color.
For ready-made ABS plastic panels, you can also check out Crutchfield, they usually have some mounting panels for certain cars and there's usually a list of what drivers fit, otherwise you have to get the measurements. The diameter is easy to match to the mounting panel but the depth is usually the problem.
