roBernd
- May 9, 2010
in my opinion, yes, they suit both genres. The bass might be somewhat too neutral for some guys if you wanna have a "in the club feeling" with bloated boomy bass distortion.
Sturdy... well, I guess, but I wouldn't throw them around or sit on them. Also, they are not suited as portables.
I recommend them for production purposes, because they are quite flat compared to any of the headphones mentioned so far.
The GMP 8.35D is as sturdy as it can get (doesn't mid cars running over them) and a fine choice as a closed-back can. Stear far away from the Shure 940 and above... they are just horrid. The 840 is... decent or good, if you don't mind the excessive treble.
Hi roBernd,
are you saying that the HD558 are the best for both genres?
do you have any idea about its sturdiness?
Thanks a lot!
