Headphones up to 150 for mainly hip hop and mixing? (Narrowed it down to 3)
Nov 24, 2012 at 8:43 AM Thread Starter Post #1 of 3
sheepo
Hello! I'm looking for an upgrade from my old JVC earbuds (xtreme xplosives to be exact), and decided to invest in some good over the ear headphones. I'm mainly going to be using these to listen to hip hop, funk, soul, and chip tune. I listen to everything, but that's what I mainly listen to. I also produce hip hop, so I want fairly natural sound so I can mix and really hear the music I'm making. The hip hop i produce and listen to has a lot of soul samples, so i dont want huge bass or anything. My budget is 150, but I would be happy to pay less or a but more if the headphones are that much better.
I've narrowed it down to 3 things, although I'm open to suggestions:
-Audio Technica ATH M50
These seem good, and they are closed which is better for when I listen in public, but I've read that open sound better (I've never used over the ear headphones) The only downside is that I've read that they have a V shaped EQ, and if I'm producing and mixing as well as listening this may be an issue, I don't know.
-Sony MDR-V6
Some say these sound harsh and have very bright highs, which is good. Not many downsides that I've found. Plus, they're cheap.
-Grado SR80i
First off, I love how these look. I've read that they are better for rock though, and not sure how they stack up with hip hop. I'm leaning towards these, can't find any downsides.
So, is my analysis correct? Which do you think is best for my needs? Am I missing any gems? Sorry to open another one of these threads, but none of them seem to focus on someone who listens to a lot of hip hop and soul.
Nov 24, 2012 at 3:23 PM Post #2 of 3
The ath-m50's fit the bill!
I don't really feel the "V-shaped EQ"
They are very comfortable and sound better the older they get!
It has a nice natural sound to them. The closest true to source you might get for that price range!
Nov 24, 2012 at 6:33 PM Post #3 of 3
-Audio Technica ATH M50 It's not too V-shaped that it would be bad for monitoring/producing. Apparently many people use it for the same purposes
-Sony MDR-V6 If you're looking at these, I'd also suggest the SRH440/840. Less harsh, more balanced.
-Grado SR80i Not the best with hip hop. A bit too thin sounding for that kind of stuff. Way too coloured for monitoring/producing.
If you want open, you could try out the K240, they're pretty decent. I'd also look into the HM5 and KNS8400.
