A_Dying_Wren
- Jul 20, 2009
Hi. My UM3X, non-removable cable, has recently totally stopped functioning on the left side. The right side seems to be as normal. Multiple sources confirm this and no amount of wiggling the cable helps. I took reasonably good care of them, always curling the wires and never bending. However, they died a short while after I washed the cable taking care not to let water touch the earphone itself. I'm wondering if the cable or the 3.5mm jack got corroded.
I think I might try to reshell them but I'm looking for any hopefully not too complex/expensive way to verify if the drivers are still working before I do so. Any help would be much appreciated.
Thanks
Thanks
