Help me pick my next Headphones!
Oct 16, 2011 at 8:26 PM Thread Starter Post #1 of 33
amIefficient
Okay so I'm looking for some new headphones;
They have to be closed over my ears.
Price under $250
Able to drive sound from an iPhone
Stay on my head (I'll be working out with these on)
Durable.
The types of music I listen to is Trance and Hip Hop. I listen to all other types of accoustic, but my ear for accoustics music isn't as good as it is for trance and Hip Hop. For example I can pickout a large difference in 320 kbps to 256 with trance and hip hop, but if it's accoustics I wouldn't be able to tell the difference.
Appreciate your help, thanks.
Oct 16, 2011 at 9:37 PM Post #2 of 33
Also I'd prefer ones that didn't throw in unnecessary bass a.k.a Beats :p
From what I've read the following phones have been suggested;
HFI-580's
Denon d2000's - A little out of my price range, but if it's REALLY worth it I'd do it
M50's
shure SRH840
So here's my main concern; Can these drive an iPhone? If not, would a portable amp that fits in my pocket be possible or even realistic and work?
I'd like to stay in range of 250 bucks, but if I can't get sound that's sastisfactory, do I have to get a completely different mp3 player altogether? That would be a pain.
Oct 17, 2011 at 4:15 AM Post #5 of 33
Shure SRH840, SRH940, JVC MX10, DT1350, P50 and B&W P5.
Oct 18, 2011 at 12:13 AM Post #8 of 33
M50 might be the only headphone that would not only clamp hard but it will more or less survive a 300pound
weight being dropped on it.
Oct 18, 2011 at 12:23 AM Post #9 of 33
X2
Just keep in mind though you will have issues keeping it it on your head if you lean back.
Oct 18, 2011 at 12:36 AM Post #10 of 33
CALs (Creative Aurvana Live), great price on Amazon.
I really liked my CALs, until I stepped on them.
Oct 18, 2011 at 4:56 AM Post #11 of 33
They are definitely worth it and you should be able to find them for less than $250.
Oct 19, 2011 at 1:33 AM Post #13 of 33
X2
How bad of an issue? This is a concern if I'm benching, or even lying back in my computer chair.
Where at? Do you have a pair? Can they drive an iPhone well without an amp?
Oct 19, 2011 at 6:43 AM Post #15 of 33
I got mine from Buy.com, you can also check amazon and J&R.
The Denons are low impedance so they can be used without a amp but I like them much better with at least a portable but you have that option.
