Can you tell me if there is an option to change eq separate for each channel (left and right)?Full parametric eq now enabled in new firmware, its ****ing great
HiBy R6 III (Gen 3) Android digital audio player, Dual ES9038Q2M, Class A / AB amplification switch, Snapdragon 665, Open Android 12 OS, DSD512 / PCM768
- Thread starter gLer
Not as far as I know of, why would you want to do this? - hearing imbalance/loss?
Yes, because of moderate hearing loss in the higher frequencies only on one sideNot as far as I know of, why would you want to do this? - hearing imbalance/loss?
Ahh bugger, as far as I know you can only adjust the balance between channels.
UrbanAnimism777
Has anyone been having trouble accessing their SD card music library on USB Audio Player Pro? I added some albums and now the app stutters and crashes every time I want to access them. I have no problem at all playing my library through Hiby Music, so I'm sure it's not my SD card being funny.
FlacFan
- Mar 10, 2015
Nope. Mine runs every day for several hours. Even switching between local and Tidal tracks and not missing a beat.Has anyone been having trouble accessing their SD card music library on USB Audio Player Pro? I added some albums and now the app stutters and crashes every time I want to access them. I have no problem at all playing my library through Hiby Music, so I'm sure it's not my SD card being funny.
Cheers.
On Aliexpress, Hiby has the R6 Gen 3 on doorcrasher for only 429.81 US at their store. If you use the code 24AN20, it brings the price down even further to only 403.47 US. This is a bloody awesome deal.
https://www.aliexpress.us/item/3256....0.0.314a38daBZyBqn&mp=1&gatewayAdapt=glo2usa
damintoell
UAPP is my main player and no issues here. Can only recommend the basic things to try: make sure UAPP is up to date, uninstall and reinstall it.Has anyone been having trouble accessing their SD card music library on USB Audio Player Pro? I added some albums and now the app stutters and crashes every time I want to access them. I have no problem at all playing my library through Hiby Music, so I'm sure it's not my SD card being funny.
jolivhires
Maybe a simple rescan library will solve itHas anyone been having trouble accessing their SD card music library on USB Audio Player Pro? I added some albums and now the app stutters and crashes every time I want to access them. I have no problem at all playing my library through Hiby Music, so I'm sure it's not my SD card being funny.
UrbanAnimism777
Thanks a lot for all your helpful comments. At the end I realized it was a corrupt file that was causing the issue but couldn't figure out which one, so I had to reformat my card and now everything's fine again.
anli
Do you turn player power off on inserting or removing microSD card?Thanks a lot for all your helpful comments. At the end I realized it was a corrupt file that was causing the issue but couldn't figure out which one, so I had to reformat my card and now everything's fine again.
I do.
UrbanAnimism777
I do too, that's why I was very confused at first! Ah well, hopefully it won't happen again.Do you turn player power off on inserting or removing microSD card?
I do.
cthomas
- Feb 7, 2014
Hi I’m trying to decide between this player and the RS2 does anyone own both? I’ve heard that the RS2 is thicker sounding can drive bigger headphones better but I prefer the look and the fact the R6 has android and can do a lot more. I’m upgrading from a ZX300 Walkman
PeacockObscura
I have both AND THE R6iii has more driving power 363mw at 32 ohms vs the Rs2 320mwHi I’m trying to decide between this player and the RS2 does anyone own both? I’ve heard that the RS2 is thicker sounding can drive bigger headphones better but I prefer the look and the fact the R6 has android and can do a lot more. I’m upgrading from a ZX300 Walkman
Whole the RS2 is great it's way less versatile than the R6iii
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Hi Joliv,Hi @Joe Bloggs - seeking advice on best way to resolve through warranty / service repair my Hiby R6 III. There's a problem with the 3.5mm headphone connection - which I normally don't use, so that the device thinks there's always something connected there - that is, the headphone symbol shows on status bar even with nothing connected. In fact, if I plug in 3.5mm either no sound or just 1 channel working if you swing a little bit the connection. Also, no output from line out 3.5mm tested with CR06 dock and it's a big drawback for me as I use it for my recordings etc. Both 4.4 LO and PO are working fine. I've contacted the reseller and he prompted to follow the service under warranty - problem is that I bought it in Switzerland and moved 3 months ago to Portugal - so If I send it to Switzerland (and reseller send to Hiby ) I risk to pay customs fee (as normally happens you pay at least 50CHF/USD just for the opening even if they don't charge tax) and the same can happen on device return. Can we claim directly with Hiby for service under warranty and if required send it directly ? How much time window can we expect for service / replacement of device ?
Thank you for your order and sorry to hear about this. It seems that you fell into a bit of a special case. Please email service@hiby.com regarding this issue and provide them with proof of purchase from the original vendor to demonstrate warranty eligibility. Let me know your email address via pm and I'll ask them to treat your case in the same way as a direct purchase from our online store within warranty, for this one case. Hope that helps!
Best regards,
Joe
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Total: 9 (members: 0, guests: 9)
