iliketowrap19
- Jan 27, 2017
Still waiting on the technics receiver
I also want to note that I like the feel and look of the stock velour pads.
So sad to hear. RIP @iliketowrap19 HE-6....What the hell.... my left driver just went out on the He-6....
Have people gotten it repaired and how much does that usually cost?Sorry on your behalf. Several people in this thread have blown the driver this way.
I think this is the reason why HiFiMan made the HE-adaptor: To avoid blowing drivers when using a speaker amp.
Yes it is. I purchased a new pair of NOS HE-6s from Amazon. They came with a huge gouge in one of the ear cups. It took Hifiman quite a while to find a replacement pair under warranty.Yea... the stuff about quality control is really true about the HE-6. It went out a little for like a brief second a few days ago when I was still running it with the R2R11. I've been really cautious about how much power I feed it with a technics receiver that arrived but was listening to a song not too much power, tried to up the bass, and pop it goes out.... If I get this repaired I'm most likely going to sell it.
How much would a broken pair sell for. I'm really upset about this and don't want to deal with the headache of dealing with customer support.Yes it is. I purchased a new pair of NOS HE-6s from Amazon. They came with a huge gouge in one of the ear cups. It took Hifiman quite a while to find a replacement pair under warranty.
HifiMan's customer service is excellent though. They offered a pair of HEXs and a pair HE1000s. I didn't want to spend more though.
I'm not sure on the amount you'll be able to get for them. The problem you have is the drivers are all matched. So you can't pull one driver out of a set of HE-6s and use it in another set and get good results. I would just contact Hifiman and have them take care of it. http://hifiman.com/servicesHow much would a broken pair sell for. I'm really upset about this and don't want to deal with the headache of dealing with customer support.
I think if you search this thread that it is already mentioned here.Have people gotten it repaired and how much does that usually cost?
Vegan pads were popular a few years ago, but I don't see people recommending them anymore. I used to have Vegan pads on my HE-6, but after trying leather (or protein leather) pads with memory foam, I have never even considered going back. Of course it depends on what you value most, so if large sound stage and airy sound is top priority, then velour / micro suede will be a better choice. If you one the other hand want the best and most sub bass as well as punch, then go for leather / pleather with memory foam. I have put thick cloth on top of my (protein) leather pads which gives me both the best of both types.what pads are you using with your HE-6 ?
From what I've heard, velour pads are good and prefered over the pleather ones.
As for other pads, Audeze Vegan are often recommended but unfortunately not available anymore.
