HifiMan HE6 V2 Adorama
Dec 3, 2022 at 2:38 PM Post #1,621 of 2,685
Superb deal indeed, however, for someone like me who paid over $576 in the past will have a bitter taste in their mouse.
I paid $599.00 when I bought. Worth every penny.
If someone gets a better price, congrats! :thumbsup:
Dec 3, 2022 at 2:41 PM Post #1,623 of 2,685
Can I drive these headphones with FiiO K7?
Not a good idea.
Is JDS El amp II+ enough for this?
  • Output Impedance< 0.7 Ω
  • Channel Balance+/- 0.56 dB
  • Max Continuous Power, 600 Ω160mW (9.8VRMS)
  • Max Continuous Power, 150 Ω650 mW (9.8 VRMS)
  • Max Continuous Power, 32 Ω - Standard1.3 W (6.53 VRMS)
  • Max Continuous Power, 32 Ω - Boosted2.3W (8.68 VRMS)
If you're looking at an amp to buy for HE6SE V2 then no.
Dec 3, 2022 at 2:46 PM Post #1,626 of 2,685
Probably the best bang for your buck is going to be finding a +100WPC home theatre receiver and driving them directly off the speaker taps. If you're lucky, you can find a good used one for under $100. You can stay under $200 easy.
Dec 3, 2022 at 2:56 PM Post #1,628 of 2,685
Do you know of something inexpensive that can drive them? an all-in-one?
A used receiver or speaker amp. None of the inexpensive all in ones have enough power to bring out the best. Violectric is about the only brand I can think of and they're very expensive.
I don't want LP or A 90. What other options do I have?
Probably the best idea is what @dstarr3 said.
Also, if you guys can find a Lyr 2 that should work. Mine is boxed up for sale so I can't test it.
Dec 3, 2022 at 2:59 PM Post #1,630 of 2,685
Lyr OG didn't have enough power
The Lyr 2 is much more amp than the OG. The way they keep the same names for totally different amps is schiit :wink:
Dec 3, 2022 at 6:18 PM Post #1,631 of 2,685
I paid $699 for the v1 in 2018. The enjoyment over these past years is worth the delta in the price for me.
Which mouse? 🐸
Dec 3, 2022 at 7:18 PM Post #1,633 of 2,685
Jot 2 or Lyr 2+ - can do it. Used Rag 1 for a few bucks more is very able.
Cheapest would be a 1990+ Reciever of 50 wpc+ that doubles power from 8 to 4 Ω.
My advice is never buy an amp with a DAC built in. Amps are pretty stable design wise over time. DACs are changing fairy rapidly.
Dec 3, 2022 at 9:52 PM Post #1,634 of 2,685
Dec 3, 2022 at 10:55 PM Post #1,635 of 2,685
The good thing about Planar headphone, especially HE6SE, is very easy to EQ with good result.
However, I have been comparing HE6SE with ZMF Atrium recently and I found Atrium is superior in scenarios such as live performance. Mostly due to the timber and staging/imaging. Atrium gives me way better sense of the reality.
