CZ Eddie
- Nov 20, 2012
Hi, I just learned there are 2.4Ghz earbuds out there with 100M range that use a USB dongle. So, you could plug the 2.4Ghz dongle transmitter into your Android TV and listen to low-latency audio from it up to 100 meters.
I'm looking to stream audio from a Shield TV with some active noise cancellation so I can listen to TV while mowing my yards.
What are some options for me to look at?
I'm not particular about earphones vs earbuds.
I just need really good ANC (Bose QuietComfort 2 work great) and ~100 meter / ~300+ feet range.
