Mr.Sneis
- Feb 5, 2004
This is way more complicated than I want it to be:
http://www.rane.com/note110.html
Basically methods 4 and 6 are confusing to me -- I have no clue how to tell if my source is a transformer or cross coupled output stage!
I dissected a monoprice version and evidently they use glue on the RCA end but it looks like they combine the shield and cold to the sleeve and hot to tip. On the XLR end it looks like they bridged pin 1 and the the barrel (?), shield to pin 1, hot to pin 2, cold to pin 3. It works but all of the sudden this cable is starting to worry me.
If it helps I'm trying to go from the balanced out of either an Apogee MiniDAC (I'm pretty sure there isn't a transformer in it) and/or the balanced out of a Sony XA5400ES CDP (which I am pretty sure is not a true balanced source). Any help is appreciated! If possible I just want to know if I go for method 4 or method 6 or rip off the monoprice method.
