CosmicSheep
I have a lot of curiosities about both the D16 and the PB5. Those little user guide cards are almost not useful. Does anyone know of the existence of some more technical manuals?
For me, I don't care. It is the sound that matters and the D16 is excellent sounding, great depth, width, separation and dynamics. And easy to use. I was able to compare it to the Hugo 2 and easily prefer the D16. Natural true sound is what I enjoy.I wonder if anybody knows to what sampling rate of DSD D16 converts/oversamples input digital signals into.
Cayin’s 1 bit DAC products have available options being DSD 64/128/256 for RU7 and DSD 64/128/256/512 for N7, but there seems to be no related specification explicitly for D16.
From the product page, it shows that 6.144MHz (approximately DSD128 rate and little more) is fed into the PWM modulator and 49MHz is fed into the DAC from that PWM modulator (approximately DSD1024 rate and little more)
I guessed that this means D16 runs either DSD128, or DSD1024. If it is DSD128, it would be a bit disappointing, being inferior to RU7. On the other hand, maybe the 6.144MHz is not 1 bit and it runs DSD1024, which is remarkable.
I wonder if anyone knows well about this. I am also willing to ask iBasso directly if no one knows.
I agree with you in that the sound is what that matters. With D16 also having excellent measurement specifications, it doesn’t really matter that much.For me, I don't care. It is the sound that matters and the D16 is excellent sounding, great depth, width, separation and dynamics. And easy to use. I was able to compare it to the Hugo 2 and easily prefer the D16. Natural true sound is what I enjoy.
High noise floor of DSD64 on the D16? I have never had that and I use sensitive headphones like the Focal Utopia and the iBasso SR3.I agree with you in that the sound is what that matters. With D16 also having excellent measurement specifications, it doesn’t really matter that much.
Just curious about it, with one concern of having heard of high noise floor of DSD64, though I have seen only highly positive opinions about D16’s noise floor.
By the way, you gave us the comparison between D16 and Hugo 2 that I was searching for quite a while! Thanks!
Oh, I didn’t mean on D16. I think what I heard was about the noise floor when playing DSD64 NOS, that DSD64’s sampling rate is not quite sufficient and requires oversampling and such for high quality sound.High noise floor of DSD64 on the D16? I have never had that and I use sensitive headphones like the Focal Utopia and the iBasso SR3.
To me, the D16 has a more natural and real life sound compared to the Hugo 2. The Hugo is a very good dac and very enjoyable but there is a difference between the two.
Thanks for your information. I thought I knew what I was talking about, but now I don’t think so. I really gotta study the operations of DACs properly…I think you may be confused. The higher the DSD rate is the higher the noises, but they are pushed up further the upper spectrum by aliasing and hence antialiasing have to be more aggressive, the same as filtering. Some people like to enjoy higher DSD rate, which I was into. But it isn’t always the case. Most of it comes from the algorithms behind it and not all of them are good. The best way for the digital music as I have witnessed is actually NOS but being done correctly. NOS is actually DSD32 as it has no Oversampling at 32 bits. SACD is the rate of DSD64
Which format do you listen to most?I think you may be confused. The higher the DSD rate is the higher the noises, but they are pushed up further the upper spectrum by aliasing and hence antialiasing have to be more aggressive, the same as filtering. Some people like to enjoy higher DSD rate, which I was into. But it isn’t always the case. Most of it comes from the algorithms behind it and not all of them are good. The best way for the digital music as I have witnessed is actually NOS but being done correctly. NOS is actually DSD32 as it has no Oversampling at 32 bits. SACD is the rate of DSD64
With D16 ? That would be FLACWhich format do you listen to most?
Don't know if that is making sense as A100T is a pure Amp and D16 is a DAC-AMP or do you mean if someone's has connected A100T to D16?Hi there,
is someone able to compare the d16 to Aroma A100TB?
Thanks
I want to connect my AK Kann ultra via LO with A100TB or D16 ( as amp).Don't know if that is making sense as A100T is a pure Amp and D16 is a DAC-AMP or do you mean if someone's has connected A100T to D16?
Won't workI want to connect my AK Kann ultra via LO with A100TB or D16 ( as amp).
