iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
- Thread starter Paul - iBasso
- Oct 14, 2013
Are you certain that these cells are of good quality?Done! Just purchased batteries in the local electronic store. Installed 5000mAh batterie instead of 4400. Charging ok. Will check how long it lasts...
Sergey Pogrebisskiy
No! But something tells me they all done in one place))) Anyway the "native" ones are on order from iBasso. So will be spare ones) They came with another 2 pin boards so need to replace the boards. Native ones come with 3 pins (one for temperature if I am not mistaken) Was not easy to solder, used acid...Are you certain that these cells are of good quality?
Sergey Pogrebisskiy
After 1 hour work on average volume... Screen on. Now thinking what glue to use to attach back cover?? Should be special one which allows to disassemble the device I guess...
purk
- Sep 26, 2001
Glad it is alive at kicking again!
- Oct 14, 2013
T8000After 1 hour work on average volume... Screen on. Now thinking what glue to use to attach back cover?? Should be special one which allows to disassemble the device I guess...
anyways, did you measure the sizes of the battery packs ?
gannjunior
HI Guys
very disappointed by ibasso.
many new "super" model after 220 max and 220 max completely forgotten.
Disappointed since 220 mx was a very special (and expensive!) top model.
ibasso did not follow any updates to improve it, to update Android UX, or android OS...
Today, like it or not, an updated software is important at least as the hardware too.
goodvibes
- Dec 28, 2009
Does it still function and sound like when you bought it? If so, ???HI Guys
- May 7, 2017
HI Guys very disappointed by ibasso. many new "super" model after 220 max and 220 max completely forgotten. Disappointed since 220 mx was a very special (and expensive!) top model. ibasso did not follow any updates to improve it, to update Android UX, or android OS... Today, like it or not, an updated software is important at least as the hardware too.
Infoseeker
Still works perfectly well for me. Not sure what you'd want to be changed.
Maybe if they could update MangoOS to be more user friendly....But even the new Dap models have a MangoOS with a silly scrolling system. That is the true disappointment. Their lack of final touches to MangoOS on all models.
Shawnb
- Dec 2, 2012
If anyone is interested I've listed my 220Max in the classifieds
goodvibes
- Dec 28, 2009
Put your thumb on the right edge of a DX240 screen and the cursor works fine.Still works perfectly well for me. Not sure what you'd want to be changed.
Shawnb
- Dec 2, 2012
I just ****ed up my Max Put the sd card in wrong and trying to get it out I pushed it even more that I can't even reach it anymore. Hopefully I can send it in for repairs.
mungster
Use bubble gum and a tweezer.
