EllisDee
- May 3, 2010
OK so I wanted to upgrade my portable amp.
After going through a ton of great reviews I've narrowed it down to either the iBasso T3 or the Little Dot MKI+
I would really appreciate some input especially if someone has tried both, does one have the edge on the other?
I would be using the new amp with the following portable gear:
Shure SE530 (36ohms)
iPod Touch1g or iPod 5.5g rockboxed
iPod LOD
all lossless files (ALAC or FLAC)
Hopefully someone responds soon as I'm dying to spend some dosh
iPod LOD
