iFi audio Pro iDSD Signature and Pro iCAN Signature - The Pro range just got better!
- Thread starter iFi audio
tamleo
- Jul 13, 2010
Are you a gear geek? ) and Can you compare the amp section on the pro idsd sig to the Zen can sig? TksI added a power conditioner and filter that solved all the problems ,,, I love ifi amp and regard it the best below USD 3000. It is now official, LCD-5 and ifi pro ican siganature are married.
MalinYamato
I am somehow dissapointed that ifi does not reply.
Mr BubbaHyde
Sponsor: iFi audio
Hi I am an ifi fan with several products from ifi and have been a very happy user of pro ican signature which I use with flagship headphones from Denon and Audeze, but have two issues: the small glass window to show the tube inside went off and the line out has lots of distortions even when the DAC that feeds it is turned off.
I am sorry, I have been following the thread as I just recently got my Pro iDSD and Pro iCAN combo, I thought you had a resolution to the issue.I am somehow dissapointed that ifi does not reply.
In terms of the Tube Window, I personally have never seen that, perhaps someone here can point you to a video about Tube replacement, I would have to look myself, but I know they are out there. (In terms of taking the unit apart for possible repair).
I think your best bet on the "distortion noise" you are hearing is to open a ticket with our support to be able to describe the issue in more detail, perhaps they have run into it previously and can surely help you out.
https://support.ifi-audio.com/
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Mr BubbaHyde
Sponsor: iFi audio
I found two videos for you if you would at least like to examine the issue more closely...I am somehow dissapointed that ifi does not reply.
Cheers!!
Jefecesti
Hi,
Is the WE396a good upgrade to the iCan Pro? Should it be circle or square ring?
https://www.aliexpress.com/item/100...!sea!FI!2312507045&curPageLogUid=et0ctWo7plXm
What would be reasonably priced DAC which meets the standards of the iCan Pro, if I want to listen music from the Spotify by mobile phone? Does any dongle have true Line-Out performance?
Mr BubbaHyde
Sponsor: iFi audio
I have heard many people who have used the WE as a quality upgrade.Hi,
https://www.aliexpress.com/item/1005004477976214.html?spm=a2g0o.productlist.main.53.436f5614np74w0&algo_pvid=f254aff5-a1fb-401d-b761-4802ebf3f803&algo_exp_id=f254aff5-a1fb-401d-b761-4802ebf3f803-26&pdp_npi=3@dis!EUR!110.67!99.61!!!!!@2102169316858264819553864d075a!12000029302501071!sea!FI!2312507045&curPageLogUid=et0ctWo7plXm
If you are referring to the "getter" in the Tube I thought most were "D Ring" in those tubes for WE.
Cheers!!
Jefecesti
Have anyone been able to compare the original iCan Pro and the signature version? How much is the difference?
Is it worth to upgrade? And how much people think the difference is in the cash value?
- Mar 20, 2013
The difference is noticeable and it mainly narrows down to juicier tone, darker background and also punchier bass. This is in large part due to iPower Elite PSU, but several tweaks inside Pro iCAN Signature also factored in.
You may consider iPower Elite as a nice upgrade
adydula
- Dec 14, 2010
Wow..owning both..very subjective. Myl ears can't tell any real discernable difference. IMO not worth the price difference. Both good products. Well designed and built. If u find a good deal on the OG's. That would be fine
I have used both supplies as well..again no difference here..with $4k + cans..
nojwe
- Aug 9, 2014
Can't speak to any sound differences between the signature and og, but the signature usually sells for about $1.5-1.6k and the OG for around $1.1-1.2k from what I've seen.
- Mar 20, 2013
Thanks for your feedback! Most users reported rather noticeable changes upon going from stock PSU to iPower Elite in case of our Pro range, but it's okay if that doesn't make a difference to your ears
adydula
- Dec 14, 2010
NP..these claimed noise levels are so down in he mud it really doenst matter...Thanks for your feedback! Most users reported rather noticeable changes upon going from stock PSU to iPower Elite in case of our Pro range, but it's okay if that doesn't make a difference to your ears
YMMV of course.
As long as that supply stays solid under load and with the original PSU numbers its a really moot point.
Great products.
Lousy warranty (my personal gripe)..
Alex
festivalist
I am running a pair of Hifiman Arya Stealth Magnet from my ifi Pro iCAN Signature.
tried it both, from the classic 4pin XLR port, also from the newer 4.4 balanced out.
I know that the classic 4pin XLR has a more powerful output, so for my normal listening, I can push the volume knob up to 9 o'clock (maybe 10) when listening to the Aryas connected to this port.
when I am listening on the 4.4 balanced port, I can push the volume knob up to 1-2 o'clock to get to the same normal listening volume.
the question is now: is there a recommended port for these easier-to-drive headphones on the powerful Pro iCAN? am I missing something if I connect them through the 4.4 balanced out?
adydula
- Dec 14, 2010
No your not missing anything.
Having a volume pot at mid setting is considered normal and desired.
Enjoy the music!
Enjoy the music!
