RudeWolf
- May 29, 2011
Apparently, they didn't know how to do the render right. On mine, it's a 4-pin.single 3 Pin Balanced XLR output for Balanced Stereo?
These figures are trivial to get with massive opamp parallelization. Look at the high-ohm power figures. 300mW in 600 ohms shows the limitation of this approach as the amp is voltage-limited. A max output voltage of 13V means that with a hot source like the SU-X (5V) it can only make use of 9dB gain before clipping occurs.18v RMS out of that one too. And to think these SMSL and Topping amps are getting these kinds of power figures with $20 worth of board-mounted SMPS, while having record low noise levels. This is not a surprising amount of evolution though, given we're well into the 2020s already.
