theaudiologist1
Is DSD in general more quiet than PCM? I have a DAC that outputs 28mW into 300Ohms and my headphones are 470 Ohms at 98dB sensitivity, but surprisingly, it gets very loud even with classical on the PCM side. It still does loud enough on DSD on non-classical music, but with classical, it gets a bit more quiet and I sometimes had to put my DAC on max gain and volume for the quiet parts and it becomes harder to separate the instruments. This problem mostly got fixed by turning off replaygain in Audirvana but some classical songs are still a bit quiet in the quieter parts. But I'm just asking is it natural for DSD to sound more quiet and "flat" than PCM? Even the PCM files I upsample to DSD get more quiet. Is it also because I'm using -6dB gain in the PCM to DSD settings of Audirvana?
