DBaldock9
The SPDIF/Toslink connector on my PC motherboard has had the little hinged plastic cover come off, and the Toslink cable no longer fits securely.
I'm looking at various PCIe x1 Sound Cards, with SPDIF/Toslink connections, and the more expensive models have EMI Shielding, swap-able Opamps, 600Ω drive capability, and S/N ratios from 106dB - 124dB. There's a cheaper model [ https://smile.amazon.com/StarTech-com-Channel-Sound-Express-PEXSOUND7CH/dp/B00X7B2NY0/ ], which has both Toslink input & output connections, but also has a lower analog S/N ratio (~92dB).
Since I've got several DACs (iFi Micro iDSD DAC/Headphone Amp, Fiio Taishan D3 DAC to drive my portable Amps), and a Bluetooth transmitter, that I can connect via Toslink - I don't use any analog input/outputs on the PC.
So, is PC Sound Card S/N ratio irrelevant, if I'm only using SPDIF/Toslink output?
Thanks for any insight in to this issue.
Take Care,
David Baldock
Take Care,
David Baldock
