KB EAR Audio impressions thread
Dec 16, 2021 at 10:39 AM Post #2,327 of 2,441
Product Parameters / Specifications
1. Brand: TRI
2. Model: TK2
3. Color: Black
4. The highest supported format: hard decode 384K 32bit/DSD256(Native)
5. Decoding: Dual ESS 9038Q2M
6.Output amplification type: Class A and B (Class AB)
7.THD+N distortion degree: 0.005% (1K, dsd128)
8. Frequency response range: 10-40khz (<1db)
9.Maximum output power: 1250mw (32Ω)
10. Support headset impedance: 8-600Ω
11. Jack support: 3.5mm Stereo/4.4mm balanced/2.5mm balanced
12. Fixed level LO: 2v
13. Battery life: about 9 hours (battery 5000mAh)
14. Charging interface: TYPE-C [supports QC3.0 or PD fast charging (can be used while charging)]
15. Decoding interface: TYPE-C (OTG cable is required to connect to the mobile phone)
16. Volume: about 13cm*6.8cm*2.4cm
17. Weight: about 280g
If you want to know more, please click the link below:
https://www.aliexpress.com/item/100....store_pc_allProduct.8148356.2.57262dfe6DEImN
For this question--"Right now, you give power output at 32ohms, but is the power output at 150ohms, 300ohms.", I have gotten somewhat confusion. What do you want to know?
Ahah “what” was missing in my question.
What is the power output into a 64 ohm earphone/headphone?
What is the power output into a 150 ohm earphone/headphone?
Dec 18, 2021 at 8:20 PM Post #2,328 of 2,441
Hi Wendy, I have just begun using the KBEAR Rhyme cable (8-core) and I think it's incredible. Layering/separation and imaging is incredible with my IEMs. I am wondering if there is a better cable in your lineup that has similar characteristics to the Rhyme, but performs at a higher level? Really the holographic imaging and huge soundstage produced by the Rhyme is what I'm looking for, if it can be improved upon.
Thanks in advance. Love your cables.
Dec 20, 2021 at 9:19 PM Post #2,329 of 2,441
Wish you Merry Christmas! 🥳🥳🥳🎉🎉🎁🎁🔥
Our official store has a special activity for celebrating it. Come and enjoy it!
store link:
https://kbear.aliexpress.com/store/5017064?spm=a2g0o.store_pc_allProduct.pcShopHead_1000001819183.0
