I ordered these about a week ago. They left LA 3 days ago to cross the continent to get to me in NY. Hopefully by Friday. I think they'll be an interesting listen.
I saw these when looking for an Amazon option for the KZ Whirlwind vs ordering from aliexpress.com even though I don't have any problem with ordering from China. Just sometimes it can be almost as inexpensive and no 3 week or more wait. Occasionally its even cheaper like the Hidizs AP60 MKII. $100 at Amazon with a $30 off coupon if you buy there $10 IE800 clones (think I have the model correct, the ceramic shell ones). $130 at Penon and Ali. $10 for that box of tips. And the box looks to be a bit roomier than the 'standard' cheap round or square case so a nice bonus:
https://smile.amazon.com/dp/B0787VLNBG
Yeah, mine just arrived today. Although I got the same set on Aliexpress but without the case. I was cheaper by a few dollars, and I already have plenty of cases.
I’m going to do some torture testing of the Tennmak tips tonight - taking them on and off a couple of IEMs - to see how well they hold up compared to the overly-fragile KZ whirlwinds.
Hopefully the Tennmak whirlwinds don’t tear when you breathe on them wrong like the KZs.
Update on the KZ vs Tennmak Whirlwind/Turbo wide bore tips.
After installing on numerous IEMs, including some with very large bores, the Tennmak Whirlwind/Turbo tips have held up as good as new with zero tearing.
I was very rough with the tips - pulling, tugging, stretching, picking at the top edge, rolling them between my fingers - things that would have destroyed the KZ tips (as a brand new set of KZ tips can tear when simply removing them from an IEM on the very 1st try). The Tennmak tips passed with flying colors.
The Tennmak tips are identical to the KZ tips in shape and dimensions, but the Tennmak tips are made of a little softer silicone. Using a magnifying glass, I can also see that the Tennmak tips have a bit thicker reinforcement where the 'turbo fins' meet the edge of the core (where the KZ tips normally tear). The combination of the softer/more flexible silicone and the tiny bit of extra reinforcement is probably exactly why the Tennmak tips ddn't tear in my test.
One nice thing about the Tennmak tips when bought on aliexpress (NOT Amazon), is that you can specify ALL 1 color and size out of your (9) pair kit. So for example, all M clear/white tips. You cannot do this with the KZ tips, so when getting the KZ tips you end up with 2/3 of the tips unusable because they are the wrong size.
For example, if you wanted to obtain qty (9) pairs of M sized KZ tips, you would have to spend a total of about $12 on (9) full sets (plus you'd end up with a boat load of S and L tips). Compare that with the Tennmak kit, where you will be able to specify 9 pairs of M tips for a total of $8 (for the kit without the zippered case).
So the Tennmak tips are not only better quality (in my tests), but cost 25%+ less.
Here's a link to the Tennmak tips from the official Tennmak store:
https://www.aliexpress.com/item/TEN...d-ear-tip-earphone-accessory/32808506339.html
I will provide the disclaimer that I only torture tested 2 (out of 3) colors included in the Tennmak kit, and I only tested 2 (out of 3) sizes - the sizes I don't use so I wouldn't have cared if they tore. It's possible that I just got lucky and happened to have tested the 2 strongest Tennmak tips out of the 18 in my possession - it's possible some of the remaining 16 would have torn. So basically I can't guarantee that all Tennmak Whirlwind/Turbo tips will never tear (YMMV), but in my testing they kicked butt.
They have my seal of approval, and I know I won't be buying any more of the KZ Whirlwind/Turbo tips once my existing stock is depleted from tears.
