Apr 30, 2014 at 7:42 PM Post #51 of 64,256
For the R3, after a decent amount of burn in and finding the right tips, I still recommend taking the front screens out. They are adhesive backed and can be put back if you so choose. I actually found a bit of debris stuck to one side that gave the slightest imbalance between the channels. A slight bit lower in the blocked side but not enough that fit couldn't even it out. Besides that they seem a bit less constricted and the balance shifted a bit more towards the mids/treble than before and also a bit "cleaner" sounding. Might be worth a try.
May 13, 2014 at 3:23 PM Post #54 of 64,256
I like the ED1 and R3-Pro for what they are, unbeatable $8-12 earphones. The cable on the R3 is killer, and worth the price alone easy.
They just can't compare to the $60 Ostry and Havi Pro. I'm hoping KZ tries for a cheap top tier model in the future.
where do you see the r3 for 8-12 dollars? Aliexpress is the only place I see them and they are like 25-35 bucks.
May 23, 2014 at 10:32 PM Post #57 of 64,256
KZ ED3 half price, $25.50 shipped.  Has anyone besides Mochill heard them?
http://www.aliexpress.com/item/KZ-ED3-acme-silver-grade-HIFI-fever-in-ear-headphones-The-transient-heavy-low-quality-earbuds/1869010918.html
May 24, 2014 at 6:50 AM Post #58 of 64,256
No but i ordered some yesterday because of the price cut, and I like KZ anyway.
