I guess designing and building is part of it too...
L0rdGwyn's DIY Audio
- Thread starter L0rdGwyn
Yeah designing and building is fun, but it certainly can be stressful at times.
g0ldl10n
Which Simpson meters are you waiting on? NOS or new production Simpson meters?Layout and chassis plans are maybe 80% done. Still waiting on the Simpson meters
Just curious, because I will be using a pair of NOS Simpson meters in my current build .. they aren't flashy at all but I love their look, and they also are quite small so they won't require much real estate which is nice. I have tested them and they are very accurate (practically speaking when measuring alongside a DMM), surprised me how accurate.
Those look cool. I use new production Simpson meters.
g0ldl10n
I gave this a try today and found that I like the mu follower quite a bit more.Another thing you could try with a dual triode that accomplishes similar goals to a mu follower is an SRPP stage.
However, I have many parts on their way from DigiKey and Mouser which include BJTs and MOSFETs and will be giving the SS CCS solutions a try this coming week. The main obvious advantage here would be dropping the need for the 2nd triode, which is expensive (relatively speaking ofc) and no loss of the B+ voltage.
I am wondering if I will even hear much of a difference if I am not running the triodes very hard in the first place.. guess we will see.
I've never done a head-to-head, but the transistor CCS from a technical standpoint is superior. Whether or not that translates into better sound I can't say. From a complexity standpoint though, the transistor wins big time.
g0ldl10n
Yes, ofc, like nearly all (maybe all) SS versus valve solutions are technically superior, the better sound thing is the question.I've never done a head-to-head, but the transistor CCS from a technical standpoint is superior. Whether or not that translates into better sound I can't say. From a complexity standpoint though, the transistor wins big time.
Hmm, well this gives me an idea of how I can compare the two sound wise efficiently. My current prototype setup has a 3rd octal socket sitting in the middle of the two required for the mu follower, so guess I will build the SS CCS solution on that socket since we get to drop 2 triodes, and then I should just be able to unclip/clip a few of those alligators to switch between the two very quickly.
g0ldl10n
Reminds me, have you ever tried the B-Follower which still requires two triodes but replaces the cathode bias resistor on the CCS top triode with a BJT.. this also removes the need for the input coupling cap of traditional mu follower, or is my understanding. I am also going to give this a try.
whirlwind
Looks killer Keenan!Did some testing today to see if my heater regulator is happy on top of a DC lift, all looks good, so we can move forward think I have everything I need to finalize chassis plans, just gotta sit down for a couple hours and design one last PCB and knock out the last chassis details in AutoCAD.
Listening to some tunes on the two-channel setup. Got my EAD DSP-7000 back from Noble Electronics, recapped, new output op amps, and some other little modifications. Burning this baby in.
Those thoriated tungsten filaments have to be the best tube glow....ever!
Landfall is on hiatus for a few months, so HY69 amp and LCR phono projects are on hold. While I have the extra time, I'll do all the other planning and building for those projects, but I can take it slow. Got my new PCBs in, I'll probably start stuffing those next week and maybe build the umbilical cable. Aegis release will keep me busy, plus I have a lot of work stuff going on anyway. Decided to pull the OTL out of storage, listening with some Sicte 6J5GT and Cetron 6336B.
- Oct 18, 2016
What's the rest of your chain? Particularly interested in your source chain.Landfall is on hiatus for a few months, so HY69 amp and LCR phono projects are on hold. While I have the extra time, I'll do all the other planning and building for those projects, but I can take it slow. Got my new PCBs in, I'll probably start stuffing those next week and maybe build the umbilical cable. Aegis release will keep me busy, plus I have a lot of work stuff going on anyway. Decided to pull the OTL out of storage, listening with some Sicte 6J5GT and Cetron 6336B.
Source is my own DAC, a NOS design, uses a pair of vintage PCM63 chips in parallel per channel, transformer I/V conversion, into a transformer coupled tube output stage. No signal caps between the DAC output and the RCAs outs, just tubes and transformers.
Total: 12 (members: 0, guests: 12)
