6Channel
- May 4, 2004
Gotta own up to it: this sucker eats batteries.The OEM batteries were not that great. I had two of them and they had to be retired even sooner than the aftermarket batteries.
Just gotta be in "high impedance mode" if using TRS jack - I got a coupla dirt-cheap 4" 60Ω male-to-female in-line TRS cords, forever taking worry out of trying to force quad implementation; however, I now only have one can well under 300Ω.Hey all,
I hadn't been using my V20 as much, but wanted to get back to using it. I tried to do a search, but I could not find a result for my query.
My question is: What volume setting should I set on my Quad DAC so that when I use the 3.5mm adapter with RCA ends to connect to an electrostatic energizer, that I will get line-out volume so that I can then use the electrostatic amp to control the volume? I was guessing 60 or 65 out of the max of 75?
I am also getting the "external audio device is connected", although I was hoping it would trigger the high impedance mode. I know about the Y-cable trick, but didn't know if it was worth introducing into the chain, since I will be controlling the volume on the amp. It does beg an interesting question, which is that should the line-out volume setting be the same for the external audio device setting as it would be for the high-impedance setting?
Prior to this, I had been using a USB-C cable to connect the V20 to a Chord Mojo, which then went to the Stax amp, and then to my SR-009s. The Mojo can be set to line-out by pressing all three balls at the same time when powering on. I know this is likely a better setup, but sometimes when the Mojo battery is depleted, I want the option of being able to take advantage of the Quad DAC.
Thank you!
I think it may be possible to get 1v or 2v out of the V20 with the cable you described. It has been a while since I owned the V20.Hey all,
Thank you!
Need more specifics: Perfine store shows nada in "battery" "batteries" nor "V20".Perfine store from AliExpress. After 5 full charge and discharge cycles, they really show 4100 mAh! I couldn't believe it. I bought 10 of them. I haven't bought the extended one. It turns the phone in a brick and lasts for 3 days, so I have read over forums. Not to mention the absolutely new V20 phones for 70$ each. I bought 3. The Korean version works great in Europe and I updated to Android 9 via LG Bridge. Unlike the Korean V10...
https://it.aliexpress.com/item/3296...st_main.5.27ab3696hh3mxI&gatewayAdapt=glo2itaNeed more specifics: Perfine store shows nada in "battery" "batteries" nor "V20".
Polky74, I've bought my 2 batteries from Amazon based on good buyer reviews - they're pretty cheap, and I can afford to swap 'em out or recharge for music use (might not be a good solution if I used it as a phone all day long).
TKX !! Found it !! will be on my next order . . . .
Try the ifixit website. They did have batteries for the g7 last time I checked, maybe they will have some for the v20. I think I would trust them as a source more than any of the other usual suspects.Can you advise me where to buy batteries for my beloved V20 (even non-original ones)? In the last 2 years I have purchased 6 (original or otherwise) but they all have a ridiculous duration... if I turn on the screen after two hours it's over. Thank you.
You have some questions which suggest you may not have utilized a cell phone as a music player. I just HAPPEN to have just received a TMob V20 (918) offa ebay from an identical promotion. I already had an "original" V20 dedicated to music on which I foolishly accepted a Nougat > Oreo upgrade 2 yrs ago that changed many things, like disabling the fabulous FM radio. The V20 I received last week HAS the FM and (the reason for V phones) the Quad DAC. It comes with NO user guide beyond basic instruction on how to "fire it up" - I recommend downloading the very sizable pdf manual from either LG or one of the mobile carrier sites. Basically, the Quad DAC will kick in automatically whenever an impedance is detected (comfortably) above 50Ω (mine are 600Ω). There are several "tricks" to activate the Quad DAC, which you'll find discussed many places in this long V20 thread. And, yes, the Quad DAC is the primary feature of this phone. My new V20 arrived, to all appearances, sealed-as-new: the phone was "rattling" in the box, but everything I see indicates it is likely a mfgr re-pak - a very convincing one. Still has Nougat & FM radio, which even suggests it is "new old stock", because a refurb would surely have a later s/w pack. I'm just getting it configured this week (with Neutron), so I haven't wrung out everything. It definitely "looks" different in a number of ways, the most pressing that it doesn't (yet) display "per centage batt left" on home screen.Hi all! I'm really happy to see this thread.
Recently I bought a LG v20 from ebay and I'm waiting for it to arrive. This the page of the product that I bought. The seller says its "New Sealed", but I'm kind skeptical about that. I saw two videos on YouTube (here and here) that a person made and it he thinks that those so called new LG V20 are just refurbished ones. Anyway, I'm ok with that, as long as the cellphone has the quad dac and functions as a music player normally. I'm not interested in using as a cellphone to call people, or to take pictures or install other apps. I just want it to use it as a DAP/PMP.
I was just wondering, when I have the v20 in hands, if I need to do anything to activate the quad dac. Or if it activates automatically upon playing music.
My favorite music player is musicolet. I understand that there are more technical music player apps like usb music player that activates the quad dac, but I just love the design of musicolet despite not having a lot of audiophile options. Will musicolet being able to use the quad dac?
If anyone can help me with that I'd be really glad!
mood: anxious for the arrival of my v20
edit: just to add that my library is of flac files
