How about Beyerdynamic cans? I have avoided them because I'm treble sensitive but their TYGR 300 R apprently doesn't have that problem.
Nope. Definitely exclude Beyerdynamic.
The average males ear height is 63mm and Beyer cups are only 58mm. Also their driver is flat so there wont be enough depth.
Your best option at a reasonable price will be the Sennheiser HD5XX series. For best sound, if you can’t use prametric EQ (through PC/Android software or external hardware DSP) then you should grab a HD560s. If you can use PEQ, then just pick one which Oratory1990 has already measured.
If you want a gaming headset, another option might be the PC38X and PC37X. Although I haven’t tried these myself.
Lastly, for a closed-back headset.. I actually find the Cooler Master MH751’s to be reasonably comfy. They have angled drivers and decent enough internal space... although definitely more snug than the HD5XX family.
