archaicspartan
- Jan 15, 2014
Hello Everyone,
So I am currently shopping for some in ear headphones that will not break the bank, but will provide me the best sound possible.
My preferences:
I listen to a huge range of music from techno, rock, indie, hip-hop, rap, etc. I really want headphones that give a clear and filling/warm sound. I enjoy base (and a good deal of it), but too much and I start getting a headache. I usually like it to add to the sound rather than physically rock my head. So overall I want something with clear highs and mids with a slightly stronger low range. (I am bad at explaining).
I want at least a single button that works with android to skip/pause/previous and mic.
I have looked a bit and have heard good things about the Klipsch S4A which is on sale on Amazon for the first model. I am wondering about the Denon AHC300 which has great reviews, but many things say there is a TON of base and also I don't know if its buttons will work for android (at least to pause play or skip). The V-Moda remote remix isalso a strong consideration because they look like they are built well, but I know they will function as, at most, one button press which is fine, but I don't want to be paying extra for multi-button when I can't use it.
Denon AH-C300: http://www.amazon.com/Denon-AH-C300-Urban-Raver-Headphones/dp/B00858I4M0/ref=sr_1_12?s=aht&ie=UTF8&qid=1389823810&sr=1-12
V-Moda Remote Remix: http://www.amazon.com/V-MODA-Noise-Isolating-Headphone-3-Button-Control/dp/B002HR0YLY
I was just hoping I could get some opinions on these or other options. I am coming from Skull Candy ink'd which worked well, but broke a lot. Anything with equal or better sound is great. I also have some Bose Companion 3 desktop speakers which have the sound quality I am seeking and the type of base I would like for in-ear headphones because it doesn't move the room, but it strongly adds to the depth of the music.
THANK YOU!!!!
My preferences:
THANK YOU!!!!
