Lotoo Paw 6000 (2019)
Feb 23, 2020 at 9:48 AM Post #481 of 1,459
Still on the fence to get it... PMEQ/ATE seem to be very useful features, even though I hardly EQs. No, my main concern, which might sound odd, is the PAW 6000 playing files gapless? I mean absolute perfect gapless playback. I have some electronic mixes that cannot be enjoyed otherwise. Thanks for your help guys
Feb 23, 2020 at 1:08 PM Post #482 of 1,459
Yeah I can't help you there, there is a gapless option on it but as far as is it going to work with your specific mixes I think you would be better off going somewhere to demo it. The gapless option is just off and on I know some DAPS you can alter it a bit.
Feb 23, 2020 at 1:19 PM Post #483 of 1,459
Ok, thanks anyway.
Feb 24, 2020 at 3:37 AM Post #484 of 1,459
In case anybody is interested, I have put up my Cayin N6ii for sale (come with Dignis Scalia light brown leather case). Posting here since I am aware there was a few of you debating between the Paw 6000 and N6ii before. As for me, I am jumping on the Lotoo Bandwagon! Priority to local Singaporeans (because I am currently here and prefer to deal locally). Cheers!
Listing: https://sg.carousell.com/p/cayin-n6...730160&t-referrer_request_id=7UhCAUzBOrnDQemh
Feb 26, 2020 at 8:34 AM Post #485 of 1,459
Hey guys, went to test out the 6000 today at local dealer and it doesn't want to read my Lexar 512 GB card. Every time I plug the card in, it goes ballistic yellow on the screen. Has anybody encountered this with 512GB card? My 256GB seems fine with it. Same situation with the Paw Gold Touch. Make me wonder whether it is my card, Lexar, or the DAP...
Feb 26, 2020 at 8:46 AM Post #486 of 1,459
Since the 512 GB card does it in two different Daps and the 256 GB card works in both, I would think the problem is with the card.
Feb 26, 2020 at 8:54 AM Post #487 of 1,459
FiiO also had issues with the 512GB Lexar cards in the M11 and it was why they removed the second card slot with the M11 Pro, so it might be something specific to large capacity Lexar cards.
Feb 26, 2020 at 9:10 AM Post #488 of 1,459
Did you try a different brand 512GB micro SD card and the 6000 reads fine? If that is the case, I might have to buy a Samsung or Sandisk urghh
Feb 26, 2020 at 9:17 AM Post #489 of 1,459
Sorry, I don't have 512GB cards to try. I just remembered FiiO reporting the issues they were having with Lexar.
Feb 26, 2020 at 9:26 AM Post #490 of 1,459
Thanks! Probably this should be a caveat for future Paw 6000 owners to avoid Lexar when using this DAP? I will try my card again in a different dealer tomorrow. As I am planning to purchase this DAP, I really want to make sure. Will report back. In the meantime, can anyone share your "success stories" with a larger capacity micro SD card (512GB and up) with the 6000/Gold Touch?
Feb 26, 2020 at 9:52 AM Post #491 of 1,459
I have a 512GB Samsung Evo card that works fine with Paw 6000.
Feb 26, 2020 at 9:57 AM Post #492 of 1,459
Thanks. I think I am cursed with this Lexar card :slight_frown:
Mar 31, 2020 at 4:11 PM Post #495 of 1,459
Hi,
Have the PAW6K on order can anyone recommend a decent cable as need to change to 4.4mm balanced.
Any help appreciated.
Thanks.
