Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Dec 29, 2023 at 6:05 AM Post #8,866 of 9,250
Recc this 6N SPC cable, if you are into light and thin cables that do not tangle easily and are inconspicuous. You can hardly feel it on your ear, so I use it when going out. Qdc option can be requested via chat as well.
https://a.aliexpress.com/_ooAYJXW
Dec 29, 2023 at 10:14 AM Post #8,867 of 9,250
Have ordered myself the ARTTI NOVA cable 7N copper and modular for AU$44 (US$30) inc tax. Seems a bit of a bargain, will report back when arrives.
https://a.aliexpress.com/_mt4AGhW
Btw - listed price is higher, but coupon brings price down.
Dec 29, 2023 at 10:20 PM Post #8,869 of 9,250
Huh, I added the Purplese to my AE cart a couple of hours ago and it was £14 or so. Just looked now and it’s £120?! 😂
I only ever buy the NiceHCK cables on sale! There area a lot of stores on AE that stock them. Sales and special offers come up pretty regularly.:rolling_eyes:
Dec 29, 2023 at 10:50 PM Post #8,870 of 9,250
Dec 30, 2023 at 2:11 AM Post #8,871 of 9,250
Dec 30, 2023 at 7:09 AM Post #8,872 of 9,250
Anyone know if TRN cables with 0.78mm 2 pin can fit IEMs with recessed sockets?
I just got their TRN T2 Pro16 and the .78mm has the rounded end that won't fit. The feature is called "B plate" which is the recessed rectangle end to fit into. The ones like these https://www.aliexpress.us/item/3256804798487260.html and I've got some of them on the way, the "B-Plait" option has the type to fit in a recessed type .78mm. The TRN sound transparent and thick enough not to tangle. Next week I should have the microphone kits like below. Mainly concerned with mic quality, will test that first.
Jan 1, 2024 at 1:42 PM Post #8,873 of 9,250
Can someone recommend a good cable for IE900 from AliExpress? Please make your recommendation based upon your personal knowledge, I ordered a good cable but it connects very loose and looses sound when moving the iem.
Jan 1, 2024 at 10:19 PM Post #8,876 of 9,250
Can you share a screenshot of the web page, going thru the link leads me to the main AE page, also, why N5005 if I have a specific choice for IE900 ?
Jan 1, 2024 at 10:53 PM Post #8,878 of 9,250
If that happens then copy the item number from the link and put in Ali search - 1005004799002938
Happens to me all the time as well
Jan 1, 2024 at 10:59 PM Post #8,879 of 9,250
Looks like a clone of the cable included with the Tanchjim Oxygen, which I've always been a fan of.
Jan 2, 2024 at 6:08 AM Post #8,880 of 9,250
Thanks to Superuser1 for the screenshot.
As for the n5005 connector, it's an MMCX one but a little longer so it will feet perfectly with the Sennheiser IExx, as they have a recess MMCX connector.
It's one proposition, but you can find many others as this Sennheiser models are popular .
