zerogun
- Mar 28, 2008
Yes, i've seen those specs.
So, theoretically the Abyss 1266 should sound lean, thin, odd, tonally skewed, and worse, when being driven by the (tiny) 1320mW @ 33Ω > Matrix i-3 Pro or non-pro.
Yet, on -20 (minus 20) on the Volume Knob, not +20, but -20.... my long hair is bouncing from the bass impact, because its too loud.
I think the Volume tops out at +30ish, so, its a long way to go...
When i compare the "body of the sound"...the "fullness of the tone", with a much stronger Class "A" amp, all that changes is the unit.
Where the Abyss FR should be suffering is regarding the Low End, but, it doesn't.
It Thumps just fine, using the Matrix.
Same can be said for the JDS Labs Element 2, as a matter of fact, when using the JDS I can't even get close to the 9-o'clock position when powering the Abyss 1266, and that is NOT using the "high power" switch.
Here is a quick photo of my Abyss and the 3 amps that im using to drive it today.
Really interested to hear more of your experience with this jump. I switched over from the Element II to the Matrix just today, with a pair of Hifiman Arya's. While I obviously haven't spent any amount of significant time with the Matrix, my initial feeling is that the vocals are a smidge more clear compared to the Element II.
