Meze Audio 109 Pro
Mar 19, 2024 at 2:26 PM Post #3,407 of 3,465
To me, the Arya Organic are on par with the 109 Pro (perhaps slightly better in some aspects, but also slightly worse in areas like dynamics). However, if someone is looking to an upgrade, I believe the HE-1000SE it’s a better choice.
I went from 109 Pro to HE1000 Stealth and it is very far from a sidegrade.
Pretty massive upgrade.
And yes He1000 is better than Arya Organic as well.
Mar 19, 2024 at 5:14 PM Post #3,409 of 3,465
I traded my 109 Pro's for an older set of Arya's.
I have always been curious about the Arya's and am looking forward to comparing them against the HE6se V2's.
Mar 19, 2024 at 5:17 PM Post #3,410 of 3,465
IMO it's a step up. A different flavor as well bc they're planars.
That said I still love my 109s and i still listen to them at times.
Mar 19, 2024 at 5:21 PM Post #3,411 of 3,465
I liked the 109's fine, but I never loved them. Hopefully the Arya's will at the very least, be something different.
Mar 21, 2024 at 1:36 PM Post #3,412 of 3,465
I have been auditioning the T+A Solitaire T with the IFI Gryphon using the USB C to either the Iphone 14 Pro Maz and AK SE 300 (connecting via the USB C out) and getting great results, (waiting for delivery of the Wywires Platinum headphone cable, 3.5mm, source). During this audition, I connected the 109's using Wywires Platinum headphone cables (3.5mm) directly to the AK SE 300 and then using the IFI Gryphon connected to the SE 309 via USB C. I have found the Wywires cable a great improvement over the stock cable in both instances -- however, very impressed with using the SE 300 as the streaming source connected to the USB C on the Gryphon for Qobuz and Tidal.
Mar 31, 2024 at 1:38 PM Post #3,413 of 3,465
These are such attractive headphones!
Apr 1, 2024 at 6:23 PM Post #3,414 of 3,465
anyone here with a long term review?
i have mine for a year now and i can say i love them
the pads are just so comfy and soft
and for me they sound fantastic it really seems like the treble tamed down a little after using them more and more (or i just got used to it i don't know)
these are the first headphones i could wear for hours without any discomfort.
Apr 1, 2024 at 6:41 PM Post #3,415 of 3,465
I've got a fantastic copper cable for the 109, but I can't fit the phones in the case and then be able to close it with the cable connected. So, I take the cables off and attach them again once they're out of the case. I don't think that really makes for a wear and tear issue on the connections. What do you all think? Thanks.
Apr 2, 2024 at 10:32 AM Post #3,417 of 3,465
Apr 2, 2024 at 1:38 PM Post #3,418 of 3,465
To me, it's easier to keep them in slightly opened case, than to plug/unplug the cables every time:
That's what I do unless I store them away for longer
Apr 2, 2024 at 1:46 PM Post #3,419 of 3,465
how are the copper cables compared to the stock once or hart? i am in the middle ground of beliving cable can change the sound or make them better
i more believe in crap stock cables
Apr 2, 2024 at 2:40 PM Post #3,420 of 3,465
