Got this reply about 6SN7:
In all our dacs, tube is acting as a buffer.
So, the tube is a passive compnents in circuit and so a fixed set up (bias). No needs to adjust resistors' value for most tube.
However, the tube is working on -17.5 to + 17.5 volts, quite a very low voltage in tube's world.
5670 can works on this low voltage because 5670 was design and developed for minitary communication equipment during WWII. So, it can be work on hardest enviorment such as low battery source and hard vibration. All pencil tubes were designed to be used in air plane, they also have same characteristics like 5670. 6SN7 is a commercial tube, it may also works on our dac but sound must be another issue.
Best Regards,
Jiun
Mhdt Lab
