VictorHalgaard
WARNING: BAD TRADER
Also known as HeadphoneViking.
- Aug 24, 2010
What do you think about the Fanmusic BL-1? I have seen it advertised here in China, but have never seen a review. It looks similar to the Continental - is it? How does it compare to the C&C TU (probably the only competiton at the price)?
Thanks! Just three more questions, though:
(i) You say you wish the tube was better stabilized. Do you mean it is micrphonic? If so, how bad is it - is it usable on a train or plane, for instance?
(ii) Is the battery life really only 6 hours from fully charged? Can you at least listen while it is charging? How long does it take to charge from empty?
(iii) Is it suitable for use with IEMs (e.g. Ety HF5s), or is the gain too high?
