S-C-3-1-3
- May 29, 2011
Hi,
I will be using a Hiby R3 Pro. I listen to nearly all genres. Right now, I use a Beyerdynamic DT 770 and love their sound.
Would you chose either the Moondrop Starfield or Shozy Form 1.1? The Form 1.1 is roughly $42 less expensive than the Starfield. Or, do you have another recommendation?
Thanks!
Thanks!
