up late
- Feb 19, 2013
...euphonic headphones...[ 'euphoric' is a common error on head-fi]
It is quite incredible that you find W3000ANV having "piercing upper midrange/lower treble". It shows what variations in hearing exist among people. The consensus is that W3000ANV has soft treble, I've seen W3000ANV's higher frequencies described as "magical', as "like spun gold", as "just right", as "fantastic"... I hear the same and I agree but I wish there were more of them, I wish there was like at least 10% more treble in volume. When I bought W3000ANV my hearing, that means my inner ear apparatus and my auditory brain cells, was used to a neutral sound signature. I prefer to listen to a balanced sound and so W3000ANV, which are neutral headphones, sounded right and normal to me right from the beginning.
If one is used to more bassy unbalanced sound with weaker treble then he would find W3000ANV "bright" with "piercing treble". Human brain is described as having adaptive "plasticity", that means the brain has the ability and capacity to adapt to new stimuli and information so that it can process and store this information. If a brain regularly hears treble muted music then it adapts to this sound and takes it as a norm. It even tries to compensate for the lack of treble by modulating audio signal, by adding its own brain created treble impression so that the music sounds more right. When suddenly confronted with normal balanced sound this previously 'tweaked' brain then perceives the balanced normal music as unbalanced and as having piercing treble. I've done some readings on this phenomenon and I found a research paper on hearing experiments. According to this study it takes between 30 to 90 days for an 'influenced' or 'modded' brain to return to normal hearing mode.
Ideally when one wants to evaluate headphones with a balanced sound then he or she should not be regularly using headphones with dark sound signature for at least a month, otherwise the sound impressions and evaluation of tested headphones would be 'skewed', distorted, inaccurate.
Another possibility is that you have a treble sensitive hearing due to either an ear illness at childhood or you have a congenital slight abnormality. Your 'cochlea' or part of it might be of atypical shape or you have abnormally high count of 'cillia' hair-cells in the entrance to cochlea where the high frequency sound is 'heard' and 'processed'. - http://scienceblogs.com/startswithabang/2010/05/10/dont-you-hear-that/
We 'hear' high frequencies right at the back of the ear canal where it meets the beginning of the 'cochlea' tube - starts at 20 000 Hz and then it gets to lower ones as the sound travels into the centre spiral - 200 Hz and lower. Some people have undeveloped the very end of the spiral and so they cannot hear sub-bass and low bass. For some people the bass starts at 65 hz, they cannot hear 20-65 Hz sound. Damage to 'cillia' within the whole 'bass' region of 'cochlea' means an individual hears weak, rolled off whole bass.
Nobody likes shrill treble but you might be one of those whose hearing shifts parts of normal treble into shrill resonances. If that is not case then listen for some 40 days to only balanced headphones that have a full treble, and then try W3000ANV. You'll hear different.
- http://www.cns.nyu.edu/~david/courses/perception/lecturenotes/pitch/pitch.html
- http://oto2.wustl.edu/cochlea/romesalt.pdf
- http://www.simonheather.co.uk/pages/articles/science_hearing.pdf
- http://www.noiseaddicts.com/2009/03/can-you-hear-this-hearing-test/
- http://www.businessinsider.com/image-of-our-brain-listening-to-music-2013-6
- http://en.wikipedia.org/wiki/Auditory_cortex
- http://en.wikipedia.org/wiki/Auditory_system
There are bright headphones that I am totally fine with, though.
For instance, I am okay with the W1000, and it's not as piercing as the W3000ANV to me.
I am also okay with the AD2000.
And beyond that, I can take the HE-560, HE-6, and SR-009.
And still the W3000ANV sounds "piercing" to me. I also experience this "piercing" sound with the W1000X.
It'll be interesting when I get to hear the W3000ANV again after owning the HE-560 for another while. I think I'll still find it piercing, but it'll be worth a try.
don't usually agree with zorin but i will say that i don't notice any glare in the upper mids or find the lower treble of the w3000anv piercing. the w3000anv has the sweetest highs i've heard from any can and the mids are just lovely. euphonic is the word alright.
