S Crowther
Yes. I find the same with that address. I get quick responses from sales@vinshine audio.com even for technical issues.used this email support@denafrips.com to contact Denafrips.
The replies I get are very slow.
The DAC construction is modular. From my experience their MO is to try and determine which module is faulty and then if possible send you a replacement module for you to install. Sending the Hermes in for replacement is the last resort.My Hermes make a distorted sound and creaks.
I followed all the directions that the technical support told me to do but the problem remains.
Clearly it's a hardware problem and I don't understand why they keep making me do useless tests and don't authorize the hospitalization of my Hermes for assistance.
I must add that it is the second time that the DDC has failed, previously the USB input and another card had failed, all in less than a year of purchase.
I am unlucky?
Most likely not. If it does, you only lose $?$$.Hi, I now have SU-1 and want buy IRIS, but i have tuning supreme 1A in SU-1, IRIS have 2A, he is burn out?
I have a Metrum Adagio in my speaker system. Will try connecting my Iris to it later. I understand it should work flawlessly, but haven't tried.Hi, does anyone try Iris with Sonnet Morpheus by using I2S connection?
I have read some old posts said that Hermes/Gaia have sound cracking/popping issue on I2S of Sonnet DAC (using RJ45 cable with custom pinout) and the issue can be fixed by configuring the HDMI pinout of Hermes/Gaia.
I am not sure if Iris has the same issue.
Thanks, also want to know if it will work on different sample rates (such as 44.1K/48K). Looking forward to your test results!I have a Metrum Adagio in my speaker system. Will try connecting my Iris to it later. I understand it should work flawlessly, but haven't tried.
I read a story like this. The owner had a custom RJ45 cable made. Crackles resulted- he could not confirm the pinouts were wired properly.Hi, does anyone try Iris with Sonnet Morpheus by using I2S connection?
The Iris owner's manual does not have any guide for configuring the HDMI pinout like the Hermes/Gaia owner's manual does.I read a story like this. The owner had a custom RJ45 cable made. Crackles resulted- he could not confirm the pinouts were wired properly.
I have read a similar HDMI/I2S cable story about the Hermes - all it took was assigning the right pin out configuration according to the relevant Denafrips video. Does the IRIS have I2S configuration capability?
Or roll your own RJ45 cable, to change pin assignment if needed?The Iris owner's manual does not have any guide for configuring the HDMI pinout like the Hermes/Gaia owner's manual does.
Therefore, if Iris has any issue on I2S of Sonnet DAC, it may not be possible to fix.
Sorry, I haven't get Iris yet so I cannot test it.Or roll your own RJ45 cable, to change pin assignment if needed?
