Didn’t they used to list non-desktop high end audio gear on their website as well? I don’t see the speaker amps and separate preamps, among other things, anymore. Perhaps they are downsizing the company and this is part of that downsizing? Just a guess. I own and love both a Soloist and a Soloist sl, so I am certainly rooting for them, not against.
New, Fully Balanced Burson Conductor 3X: Dual ESS9038, 7.5wpc XLR, 3.75wpc SE Headamp, Changeable Opamps
- Thread starter raoultrifan
raoultrifan
Not sure I follow you @Strat1117, sorry. This is their products page: https://www.bursonaudio.com/products/ and I can see all of their current products listed in there, and here's their shop: https://www.bursonaudio.com/shop/. I can count a no. of 8 audio equipment, what products are missing from there?
Until recently, they offered, among other things in their reference level series, high power, bridgeable amps called timekeeper and timekeeper virtuoso. I was wondering why they stopped and seem now to be more focused on the entry level, op amp based series.
raoultrifan
They stopped producing Timekeeper few years ago. I guess it's not easy to ship such monsters overseas...or not sure why they're not manufacturing these anymore. It would be nice to see a new Timekeeper 2, two pieces XLR bridged pumping up the bass into the speakers.
As for the "other things", I guess their new DAC & headamp line is a step-up.
As fir the "other things", I guess their new DAC & headamp line is a step-up.
you would think, but they’ve positioned most of it (other than the new conductor) below the Soloist SL. I am referring to the stiff above it. Primarily the timekeeper amps, but I thought there were other things too. Also, I don’t see the ancillary stuff anymore - cables, etc.
raoultrifan
Well, at the moment they still have the Soloist SL MK2 in their offer. Also, FUN is using the same output buffer created around TO-220 Toshiba transistors like the Soloist, but like you said, the voltage-gain is a bit different, created around so-called solid-state op-amps.
The V4, V5, V6 and the up-coming V7 are all solid-state inside; that means we will find the same transistors, capacitors and resistors like the gain-stage from inside Soloist. Replacing the former fully transistored gain-stage with SS V6 op-amps is not necessarily a downgrade. Let's have a look inside, to clear up things (taken from https://www.head-fi.org/threads/bur...ssion-and-reviews.854912/page-7#post-13711554):
Basically, these DIP8 audio devices are doing a great job inside PLAY/PLAYMATE/SWING/FUN/BANG/CV3Ref because they were created to be used in future Burson audio equipment. Of course, these are compatible with most audio devices that have opamps inside. This is why there's a dedicated thread about the V6 opamps.
Gerelt971
- Oct 22, 2016
Pre-ordered. Hope this will indeed sound well with AKG K812 !
the fool
- Feb 17, 2012
Is this international voltage?
raoultrifan
It has an external low-noise SMPS PSU that works an all voltages.
DarKu
Reviewer at Soundnews
DId you see the latest preview video for C3X?
I think it looks amazing
raoultrifan
...and it's playing my favorite Pachelbel song.
Well, I bit the bullet. My pre-order for the 3X has been placed via Addicted to Audio in Melbourne.
This unit is looking like a monster! I've really loved my Burson Play and wish I could afford to make the leap to the 3X.
Audio Addict
- Aug 5, 2001
How would you use a single ended phono preamp with it since all inputs are balanced?
raoultrifan
Looking for your A/B compare (if possible) between Topping D70 +THX 789 vs. C3X.
