enricoclaudio
Matrix Audio released today a public firmware update for the X-SABRE 3. You can update the firmware going into settings/firmware in your X-SABRE 3. Then check if the bugs reported by me were fixed. Thanks!!
I just wish the price can be less. Looking at the competition, $2000 would be a better price point, in my opinion, for a 9038 chip dac.
Not that familiar with streamer as I never use one. I was only referring to the DAC only. A lot of competition from DAC standpoint.What would be the competition? I don’t see anything from any other manufacturer that comes close to the X-SABRE 3 performance/features at this price or even higher. At least no one that is Roon Ready which is my main use.
Thank you very much for the kind recommendation. But I have never heard a Topping that I like.If you only need a DAC then get a Topping D90SE which I also own. The X-SABRE 3 is in another league regarding features and capabilities!!
Did I say anywhere that the X-SABRE 3 and D90SE are comparable? The OP was asking for a DAC only solution with ESS 9038 Pro DAC and both, the X-SABRE 3 and D90SE have 9038 Pro. That is all. In terms of SQ, functions and performance, the Topping D90SE is not even close to the X-SABRE 3. This is coming from somebody who owns both. For anybody not needing the streaming capabilities of the X-SABRE 3, then get the X-SABRE Pro MQA which can be found for $1999 every where.OK, that puts things into perspective: if the matrix is comparable to the Topping (or even slightly better) I’ll take it off my list.
Well, you mentioned thisDid I say anywhere that the X-SABRE 3 and D90SE are comparable?
so I assumed the sound quality is on par with the Topping. Thanks anyway for your replyThe X-SABRE 3 is in another league regarding features and capabilities
