US Blues
Thanks for reminder . When I say 'bare', do not use bare copper as is, insulate it.
That takes all the fun out of our hobby.
Yeah, the last few posts sounded like discussion of some religious beliefs. This is science!My post about power cords is not opinion nor is it a belief. I am an electrical engineer. Power conductors work the way I posted. The beliefs stated above are not scientifically sound.
Hi, I have a question about the power cord for the Yggdrasil. Are you still using the stock power cord or did you find the unit only delivered its "magic" fully after you changed the cord (if you did that, of course)?
And if you did not, I'm still interested at what point in time you believe the unit reached its full run-in (as in, a week or a month). Thanks.
But, then again....... Oops...! (ducks and runs for cover).
This started all the talk about power cords. Schitt's position is very clear on this topic. In their user manual, it says, 'Plug the end of the supplied IEC cord in here. You can also use fancy audiophile types but they won't really do anything'.
Yggdrasil and Ragnarok is lovely sounding setup. You don't need to change power cord or fuse. It won't do anything .... unless you believe that it will.
Yes, that should be possible because couple of CD players that I have used with Yggy, they have both digital and analog outs on all the time so, I do not see any issue with you implementing this.I'm wondering if anyone has hooked up an SACD player to their Yggdrasil-Ragnarok setup? I've got an opportunity to get a good SACD player pretty reasonable. My question is this...Is it possible to hook up the the player to the Yggy to play redbook cd's and also use the SACD player's DAC to play SACD discs through the Ragnarok? This player also can play DSD files through use of USB flash drives or similar input devices outside a computer or NAS drive.
Any thoughts or ideas...is this even feasible?
Thanks
Thanks
Thanks
Any Utopia owners with Rag Yggy combo? How is the pairing? Also, does anyone find this pairing too bright with HD800/S?
