What about pairing it with hd800?Well have heard most of the amp and heard some pretty expensive one this Canjam but holographic staging that I get from ECP DSHA-3F(Nickel transformer) with ZMF is second to none.
Nitsch DSHA-3FN / ECP DSHA-3F Impressions
- Thread starter Aura
- Oct 18, 2016
Of course. It's subjective.To each their own — I think this looks better than 90% of headphone amps out there.
raindownthunda
I really like the DSHA-3FN with the Schiit Yggy+ MIB. I wasn’t a fan with the Yggy GS/A1, where the sound was a little too lean. With the MIB the tonal density / weight is perfect to my ears with ZMF AC and VC.I'd love to own one of these someday — how does it compare to TT2? And what's a good DAC pairing?
I used mine with Metrum Onyx at first then Pavane and now plan to use with Sonnet Pasithea
ClicketEKlack
It sounds stellar with a $500 Topping DAC too.
Does anyone know how to convert this amp to 240V? Only these two pins and fuse need to be changed?
What about with a Qutest? How does it pair?
Also on a side note, how well does this drive Susvara?
I don’t think this amp is for Susvara.What about with a Qutest? How does it pair?
purk
- Sep 26, 2001
Ask Doug for a DSHA-4 or Ravenswood if you want to drive the Susvara.
How would this amp compare to a Mass Kobo 433?
My only headphones are in fact Focal Utopias, and I do understand that the Nitsch was designed for Focals. But, I don't want to read too much into the "with Focal in mind" slogan, to the point of not considering alternative amps just because I use Utopias.
I am looking for a detailed and neutral sound, and I don't mind a somewhat lean signature.
heliosphann
As great as the DSHA-3FN is, even with non-Focal dynamics, I just sold mine because the 433 made it redundant. IMO, it's a better overall amp, cheaper and the same form factor. Bar none one of the best amps I've hear as far as performance/price/footprint. I think it unfortunately gets overshadowed by the 394II and 465.How would this amp compare to a Mass Kobo 433?
However, if you're just using a Utopia, the DSHA-3FN is probably the way to go.
The Utopia is indeed my only headphone, but I don't see why I should get a DSHA-3FN over the 433, unless it actually performs better with the Utopia than the 433.
And if the 433 is a better overall amp, that seems unlikely.
P.S. The 394II seems discontinued, and the 465 is of course in a totally different price category.
