Noble Audio - the Wizard returns!
- Thread starter project86
- Tags
- noble audio sage noble django noble-3 noble-4 noble-5 noble-6 noble-audio noble-audio-3c noble-audio-3s noble-audio-4c noble-audio-4s noble-audio-5c noble-audio-5s noble-audio-8c noble-audio-fr noble-audio-kaiser-10 noble-audio-kaiser-10-universal noble-audio-pr noble-audio-savant triple flange ear tips
Call it Hanzo.
That isn't better than Hologram, damn kids. Saul WILL get Hologram done, I have visual proof.
cas33
- Sep 10, 2015
It varies, so if u cant see them, certainly don't use force while using the jodi vac
So only the metal-like component right? Will slightly nudging the plastic tube be fine? I've had quite some build up in the canal and I've unintentionally nudged the edge of the tube a couple of times while using the loop/brush tool
Pardon my paranoia
ScottFree
- Apr 1, 2008
Pardon my paranoia
If by nudge you mean slight contact with the plastic tube then I would expect that would be ok. The plastic tube is fairly long and starts at the front of the BA drivers covering the sound outlet before ending just before the bores. The drivers themselves are glued to the shell and are VERY solidly fixed.
Sent from my iPad using Tapatalk
cas33
- Sep 10, 2015
Perhaps I've done more than contacting. I could see some layer of plastic moving as I inserted the tip of loop tool into the small bore. Maybe the edge of plastic tube moved about 1mm?
I personally have stopped using the cleaning tools with the loops, I use a safety pin now. The one bore hole on my customs is just too small.
This guy has one amazing voice! Wow! Beautiful.
The title to this video is true. It's just none of the shoppers on the street, but me behind my computer screen.
He has more talent in his pinky, than I have in my entire body.
this video ^^
EZE99
- Feb 23, 2017
@FullCircle or anyone else who can answer,
Can it be damaging to IEMs to put them in an airtight case with a dehumidifying packet? Will something inside dry out and change the sound? Can it be damaging in any way?
Thanks,
Ethan
Thanks,
Ethan
- Jul 11, 2008
@FullCircle
Thanks,
Ethan
No, if anything it is recommended
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
EZE99
- Feb 23, 2017
Even if its a dynamic driver? Nothing can dry out?
- Jun 29, 2014
I do that...so far everything's good
- Jul 11, 2008
A bag of desiccant is really mild, it isn't like a fruit/jerky dehydrator. The hearing aid industry has recommended the use of desiccant systems for several decades.
- Jul 11, 2008
Trace Bundy, Keeping it Noble
- Jul 11, 2008
John Butler, probably could make a coffee can sound awesome
Total: 6 (members: 0, guests: 6)
