Even though it is a tight height fit I love the supplied K10 case with the BTS and my AK120mkII. Portable and very safe.
Noble Audio - the Wizard returns!
- Thread starter project86
- Tags
- noble audio sage noble django noble-3 noble-4 noble-5 noble-6 noble-audio noble-audio-3c noble-audio-3s noble-audio-4c noble-audio-4s noble-audio-5c noble-audio-5s noble-audio-8c noble-audio-fr noble-audio-kaiser-10 noble-audio-kaiser-10-universal noble-audio-pr noble-audio-savant triple flange ear tips
M Coupe
- Dec 20, 2012
Be careful with that case. I have a couple of them. I am not sure about your AK but you have to be careful it does not slide around and power on by accident. The little AKs can get scarey hot in a case like that...too hot to hold. It is amazing to me that AK would make a product without some sort of thermal shut down. Hell my k240 gets too hot to even carry in my pocket for very long.
What I did is cut out foam so that the ak is held securely in the case and does not bump around. Plus, I also always double check to make sure the AK is powered off fully before i put it in the case.
Finally, get a desiccant pack of some sort to keep things dry while in the case.
- Jul 26, 2012
As the forum is now talking about the neutrality of the Noble 4, has anyone done a comparison with the Savant (or even UERM)?
http://www.head-fi.org/t/739512/in-depth-comparison-ultimate-ears-in-ear-reference-monitor-noble-audio-4c-wizard-design
Good suggestions. I always power it off so I do not find I am out of battery before I want to listen. With the Cable on top coiled it seems to keep the AK in place.
DuxR
- Oct 19, 2010
My impressions are showing as being delivered on Saturday, when can I next expect to hear from Noble regarding my order? Do they keep you updated on the status of your order or is it just a matter of waiting until they're finished?
Under the FAQ, it says once your impressions have been received at the lab they confirm it, the next contact after that will be when they are completed, you get pictures for approval.
kalrykh
Account banned by request.
- Oct 2, 2014
One of these should fit hopefully any need in the CIEM/DAP arena.
http://www.pelican.com/case_category.php?CaseSize=Micro%20Case
The 1060 is on that list It's huge. The case that came with the Nobles actually fits the iPod + iem's perfectly (I'm getting damn tired of having to retype iem, screw you OS X, i do not want to type item). The hifi-m8 is large but it ticks off all of my boxes, as far as features go, so I deal with the extra size.
kalrykh
- Oct 2, 2014
How the hell do I get those Noble stickers?
I got 2 with my K10's. That was a while ago, I think my serial number is 133.
kalrykh
- Oct 2, 2014
I just got the white ones that look like a burger king hat
Brannan had stickers at The Show, plain white on one side with Wizard sig on the other. They might of been about 3x3 size wise.
Dilwar
- Feb 5, 2014
Looking to upgrade my Etymotic HF3 to the Noble 4 or Savant. The offering of the BTS with the Savant is really hard to pass on.
Which one (N4 or Savant) has a better sound stage and isolation?
- Jul 11, 2008
- Isolation would be the same as the external components are 100% the same.
- sound signature
N4 - reportedly wider sound stage than the Savant, but bass is a touch anemic, but a bit bolder than the ER4, great product for vocals & acoustic instruments
Savant - bass response is a bit more robust than the N4, highs extension in the region of the ER4. The Savant can expand more readily across more genres than the N4 and do so at savant levels.
Both products are packed with a complimentary crush proof box, which has been tested extensively by our friends at UPS
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
- sound signature
Thats a pretty big box, someone must of had huge ears.
- Jul 11, 2008
Brannan may still have some. We no longer produce them as our new shipping box is too short for this particular sticker to fit inside
Total: 6 (members: 0, guests: 6)
