Liono
- Jun 14, 2010
My DIY transport box.. allows earphones to be stored without always recharging up to 100% (not good for batteries). A nice addition to my 5 quid "leather" pouch.
One of my ears is too small for the smallest included rubber earbuds.
Can someone save me 90 pages and recommend smaller rubber/other earbud alternatives?
Yeah, it's funny...I had custom earplugs made and had the same issue...one ear perfect, the other-even custom-never fit the same.
I use those with mine, sound got way more refined, better clarity and soundstageMaybe try spinfit cp360?
For lithium ion batteries it's good to keep it topped up.My DIY transport box.. allows earphones to be stored without always recharging up to 100% (not good for batteries). A nice addition to my 5 quid "leather" pouch.
Thanks...I bought those and the Comply Truefit Pro. Getting both tomorrow, hopefully one or both fit.Maybe try spinfit cp360?
CP360 fits the XM3’s like a charm. Been using them since I got these babies. Sounds great too. Isolates much better than the standard tips too.Thanks...I bought those and the Comply Truefit Pro. Getting both tomorrow, hopefully one or both fit.
OcelitgolI've been spending some time with these babies. Just in case anyone need:
For EQ:
- Symbio (with foam): Clear and tight + keep it balanced. If you find stock too bassy (or loose), these might help. Note: fit the case with Small size, Medium can barely fit
- Spiral Dots: airy with expense of some low-ends, smooth. If too bassy, these probably help.
- Sprial Dots +: same with the normal version. Note: the nozzle is bigger so looser fit. They might stay in your ears when you try to take them out.
- Stock tips Silicone: neutral with little warmth. Kinda bassy for me but perfectly pleasant to listen. Good for commute.
- Stock tips Foam: ehh....okay-ish. I feel like it the extension is a bit off. They don't stay on my ears so I didn't bother testing further
- Final: Kinda similar to stock tips silicone. Feels better though. They also extend a bit further than stock.
- Comply: I don't like it. Better fit overall though. Comes with pros and cons of foam.
- Sedna Light: AIR......HIGH-RES....... They do not fit in the case regardless of size. Unless you wanna push the cap down.
@ Symbio (with foam): I LOVE LOVE Treble profile and +2 ClearBass. This is my go-to profile. You can tweak a little to make it "sounds closer to IER-Z1R" (airy, punchy, tight).
***** ClearBass = +2 | 400 = 0 or -1 | 1k = +3 | 2.5k = +5 | 6.3k = +5 | 15.6k = +9 ***** [The settings are based off some users here]
Note: I don't recommend using this EQ for wider bore like Spiral or Sedna. It sounds harsh (cymbals crashes are harsh). You can turn down the EQ as well. Nozzle size like Symbio and smaller would be perfect. Adjust ClearBass to your likings.
@ Stock tips: honestly the OFF option sounds really balance already.
@ Spiral: good with OFF (better than stock IMO)
I hope someone will find this helpful
I'd love to hear more recommendations on set-up as well.
If I need the largest tips on standard Sony and still don't get perfect fit, will large or extra large be best in Spinfit 360?Try Spinfit CP360 tips or the Xelastec tips. For me both of these work well with the XM3.
Did you have to size up or down? I need biggest tips on Sony stock and we'll still didn't get a secure fit. I ordered the large xlarge combo spin fits they arrive tomorrow wondering if I should have gone medium and large. For some reason my right ear canal needs a bigger size than left. Right now using the tips from the liberty 2 pro as I get best deals and more secure fit and am usi g the largest ( is 2 sizes up from the medium) and 1 down from largest as the 2 tips.CP360 fits the XM3’s like a charm. Been using them since I got these babies. Sounds great too. Isolates much better than the standard tips too.
I had to size down for the XM3. I usually use L size tips for my other IEMs and with the 360, the M size fits me perfectly on the XM3. However results may vary as everyone has a unique shaped ear canal. It best to try it first if its possible. Otherwise get a pack with both M and L to be safe.Did you have to size up or down? I need biggest tips on Sony stock and we'll still didn't get a secure fit. I ordered the large xlarge combo spin fits they arrive tomorrow wondering if I should have gone medium and large. For some reason my right ear canal needs a bigger size than left. Right now using the tips from the liberty 2 pro as I get best deals and more secure fit and am usi g the largest ( is 2 sizes up from the medium) and 1 down from largest as the 2 tips.
