Oppo PM-3 : The Portable Planar - Impressions
If I can use the Pandas wired with my PM-3 balanced wire, I'm in.
- Mar 20, 2013
It sure is! Thanks for sharing!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
EricDH
Maybe I can finally buy new earpads for my PM-3 then
Chris Kaoss
Exactly. Same thoughts here.Maybe I can finally buy new earpads for my PM-3 then
The meijunter pads has arrived, but i'm not satisfied with.
They aren't as soft and "plush" like the original ones.
Waiting for another on from YunYiYi, which looks like the same as meijunter.
Time will tell.
Chris Kaoss
Hi guys,
second pads arrived yesterday.
Very comfy and soft surface material.
Better than the meijunter, imo. The Yunyiyi pads are a bit thicker than the oem and meijunter pads.
After installation, it looks great and feels better, except the softer foam of the oems.
Once settled, they should be as great as the oems, i guess.
Btw.
Will buy another one for future changes.
Btw.
- Mar 20, 2013
You reckon there's any chance these will loosen up in time?
Chris Kaoss
I don't think so.You reckon there's any chance these will loosen up in time?
The foam and synthetic leather feels not as soft as the oems. while the Yunyiyi feels a lot better, like real leather, i've skips the meijunter immediatly.
Koei
- Mar 11, 2009
How did you fix your headband?Hi guys,
Btw.
Chris Kaoss
Hi Koei,
it's the original headband. Just gently wiped off the synthetic leather of the fabric completely at the bottom.
Koei
- Mar 11, 2009
Looks really good, I might try that also!Hi Koei,
Mark Up
Please clarify. If I go to the link and order the black pads, I get those crappier looking stiff "Mejunter" black pads that are pictured. If I click and order the white ones I get Yunyiyi pads. But those will be white? I am thinking about ordering those pads to try on other "Brainwavz sized" earcups on other headphones in my collection. I would want the black Yunyiyi you'd just got.Very comfy and soft surface material. Yunyiyi Pads
Chris Kaoss
On the provided link, you'll get the shape of the white pads, just black ones.
I did a second order to clarify for myself.
They'll arrive in the next days, i hope.
Mark Up
Thanks. Please let us know if they arrive as black colored pads.On the provided link, you'll get the shape of the white pads, just black ones.
Chris Kaoss
Will chime in when they'll knock my door.
