Oriolus Traillii Electrostatic Hybrid IEM discussion thread
- Thread starter tgx78
A superb song on the Trailli
I had that same Eureka moment on the Traillii Ti hence made me buy it
Mr.HiAudio
Member of the Trade: RIOBuds
Does anyone used a Azla SednaEarfit Max ?
Tanalasta
- May 15, 2003
Yes. Mild bass emphasis. Mids more ethereal. Lost just a touch of the treble magic.Does anyone used a Azla SednaEarfit Max ?
I prefer Azla Crystal if the stock tip isn’t to your liking.
Mr.HiAudio
Thank you!Yes. Mild bass emphasis. Mids more ethereal. Lost just a touch of the treble magic.
I'm worried about open holes in the sound guide, so I want to protect it from dirt
I prefer the Azla Sedna EarFitLight Short tips. As to your concern of the nozzle having a wide opening without a filter, purchase an IEM vacuum and use it whenever you see wax. I consider this a must have item.Thank you!
Amazon has the Jodi:
Jodi Consumer Hearing Aid Vacuum Cleaner
https://a.co/d/5UquyYX
And 64Audio sells one as well.
Ulan 8w in the house! Such a great pairing!
Rather spoiled at the moment with Orphy, Ulan and the stock Traillii Ti cable..
Many thanks @slumberman for the recommendation!!
Glad you like it, as I followed your recommendation and ordered oneUlan 8w in the house! Such a great pairing!
It’s all @Chang ’s merit! He originally recommended it!Glad you like it, as I followed your recommendation and ordered one
latte06
any recommendation for a portable amp combo with the Traillii?
IndeedIt’s all @Chang ’s merit! He originally recommended it!
Amadeo Nospherathu
Perhaps the best combo I've heard is the Pico Origa SE, but it's hard to buy.any recommendation for a portable amp combo with the Traillii?
With ALO CDM is also a great combo, it remains one of my favorites. Both in DAC/AMP mode and pure AMP mode. There's a wide range of tubes to choose tuning, and it's really great. However, iematch is required for correct working.
It is also a great combo with the widely mentioned Aroma A100 (or A100TB) amp. It allows you to change the opamps and this allows you to tune the sound. It is also advisable to add a Power Station to it. It is not necessary, but it allows you to get the most out of it.
There is also the Mass-Kobo 475, but I have not heard it. Many recommendations though. I do have its big brother, the 465 ( fabulous ), but that is not portable.Perhaps the best combo I've heard is the Pico Origa SE, but it's hard to buy.
I never cared much for portables as I believe in Daps and then desktop. You can get great sounding Daps and desktop that will blow away any portable. But use cases do differ wildly. Anyway my point is, if you ever begin spending 1000’s on portable, look at desktop as a potential better option. Good luck.
Pico and ALO Continentals are both impossible to find.Perhaps the best combo I've heard is the Pico Origa SE, but it's hard to buy.
