Paladin79
Previously MOT: Cables For Less
I have switched between the Crack and Whammy many times but I would not call them close. The tests i will be doing involve about 20 criteria per device so I will see how those two stack up at some point, as well as the Mainline in some blind testing. Five levels for each type of criteria. Most likely there will be 15 tube amps and about the same number of solid state so if the two score closely it will definitely show.The mainline with high impedance headphones and the crack should pretty close. Compare your crack (with stock tubes) with the whammy and let us know.
